Arrgh!! Header Gaskets!
Old Feb 12, 2006 | 05:44 PM
jd_sylvia's Avatar
jd_sylvia
If I can't get the headmans to work that will be my next try.
Thanks
jd
Old Feb 12, 2006 | 07:38 PM
Randyb12's Avatar
Randyb12
Originally Posted by jd_sylvia
Ok
I used the soaking method I also heard of that years ago and it worked on the headman set of gaskets, but it failed on the MrGasket. I have retorqued twice it got a little better but still leaks. The new headman gaskets will be here soon.
Thanks guys
jd
You need to retorque 3 or 4 times in the beginning before they start leaking. doing it after they leak is too little too late. I do it after each good heat cycle.
Old Feb 13, 2006 | 08:50 PM
tomcasino's Avatar
tomcasino
I don't have headers but after swapping in a new 390 I had exhaust manifold leaks. I tried two sets of the fel-pro gaskets without sucess. They still leaked after re-torquing. Next I went with the Mr. Gasket paper gaskets. Those leaked also. I now have the Mr. Gasket copper header gaskets. No leaks.They went on easy with all of the bolt holes lining up.
Old Feb 14, 2006 | 07:17 PM
Tmod700's Avatar
Tmod700
Byson makes a really good gasket. They fit right and don't leak
I will second this one, I have been using them for years with never a leak.
Perfect port fit as well.
Tmod
Old Feb 14, 2006 | 08:09 PM
jd_sylvia's Avatar
jd_sylvia
Were can I find the Byson gaskets? Online or at a parts store?
Thanks
jd
I keep re-torqueing them and it is getting better.
Old Feb 14, 2006 | 08:14 PM
Tmod700's Avatar
Tmod700
You can look here for a distributor in your area.
Tmod
Old Feb 18, 2006 | 05:41 PM
jd_sylvia's Avatar
jd_sylvia
Ahhhhh the sound of silence
Well I installed the Headman header gaskets today with great success. I pre soaked them with a spray from a water bottle and before install I dabbed a bit of Never-Seeze around the seat area. Was real careful about getting them square before torqueing them down. I went over my torque sequence about 4 times and also put Never-Seeze on the bolts.
It runs without a bit of a leak, well not that these old deaf ears could hear.
You can see by the pictures below why the MrGaskets are so much worse than the Headmans.
Thanks all for the reccomendations and ideas.
jd
the5schlueters
Nov 12, 2013 12:12 PM
almonyspm1
Mar 5, 2012 08:51 PM
1bad67sbf
Apr 19, 2010 05:39 PM
fordman428
27
Dec 17, 2008 02:34 PM
fordman363
Apr 5, 2006 09:25 AM
