Sponsored by: Auxito
Electrical problem, not alternator
Old Sep 8, 2005 | 02:46 PM
mfgdesigner's Avatar
mfgdesigner
I thought the alternator went on my 99f150, 5.4ltr. I changed it and the same symptoms appear- it can be jumped, will show a charge but after warming for 5 minutes or less all the electrical, gages, power windows, lights, you name it go out. I figure it must be a short but.....any ideas?
Old Sep 8, 2005 | 05:22 PM
steve(ill)'s Avatar
steve(ill)
bad battery.
Old Sep 9, 2005 | 12:17 AM
mfgdesigner
Alternator/short/temper update
The battery is only 10 months old and does hold a charge. If I let the truck sit and "cool down" it starts right up without a recharge, then this sequence begins after running 1-2 minutes:
1. The ampmeter on the dash begins to "tick down", several incremental drops until it is in the red. It starts above the midline.
2. The dash, dome and exterior lights begin to dim, slowly.
3. Last, all gages go to "zero" and lights go out while the truck still runs.
4. At this point I can turn it off, wait an hour, start it and watch it repeat the cycle.
The alternator was new, not rebuilt. I assume that it must function because of how the ampmeter on the dash shows it charging good and strong for the first minute. I have checked, rechecked and prayed over the connections.
This problem started abruptly, this makes me think maybe a short or broken cable, but the sequence of events and how predictable the repeat themselves makes me think a relay or something in the electrical system
At 120,000 miles this is just broken in, where do I tickle it to make it go?
Old Sep 9, 2005 | 11:55 AM
steve(ill)'s Avatar
steve(ill)
the volt meter should not tick down. alternator can put out over 100 amps if needed. i wonder if the regulator is kicking out after a couple minutes and you are reading battery voltage only. if you had a short that big, something would be red hot after 2 minutes??
Old Sep 9, 2005 | 11:57 AM
steve(ill)'s Avatar
steve(ill)
i think i would take the alternator and battery both to auto zone for load testing. dont assume they are good since they are only a year old.
Old Sep 9, 2005 | 01:11 PM
mfgdesigner
That's just it, I'd think it would be a "sparks all over" short. I found the following thread
Alternator check for F150
C1 CHECK FOR OPEN A CIRCUIT
* Measure voltage at test point A on the voltage regulator.
* Is voltage at test point A equal to battery voltage?
Yes
GO to «C2».
No
CHECK fuse in Circuit 36 (Y/W) and REPLACE if required. If OK, SERVICE open in Circuit 36 (Y/W).
I did this check, I think the diagram that goes with this ( that will not copy to this email) is from a service manual. Anyway, in checking test point A I get only .2volts. My question would be where is the fuse in circuit 36?
Or, I am off track here?
Old Sep 9, 2005 | 02:16 PM
mfgdesigner
Ding Ding Ding
I think I got it, need to get on the scooter for a new 20amp fuse. My checks (reading threads) kept going back to fuse 11 under the hood. Looked perfect, checked it 3 times yesterday. Today I was frustrated to the point of actually checking continuity......it was open. Never saw this before but it was cracked near the inside edge. If I twisted the fuse it showed the break. I hope this is it...will let you know for sure.
Old Sep 10, 2005 | 03:37 PM
lancekilgore's Avatar
lancekilgore
hope that works if not I would have the alternator checked as Steave said.
Lance
Old Sep 10, 2005 | 10:34 PM
mfgdesigner
A bad fuse is a bad fuse. This one was fractured, not burned, that was the odd part. I've already put 250 miles on it since installing the new fuse and its running like a champ, charging the battery as it should.
Stroked Out!
Electrical Systems/Wiring
May 27, 2008 11:03 AM
Joe Finn
33
Oct 28, 2006 10:38 AM
fishmanndotcom
May 31, 2004 08:28 AM
oldesailor
May 8, 2004 10:11 PM
MTZBoeger
Jan 28, 2004 03:46 PM
