alternator amps
Old May 31, 2004 | 01:15 AM
fishmanndotcom's Avatar
fishmanndotcom
alternator amps
how do i test the amps coming from the alt? i am electrical illiterate and i have an electricla problem!
-cutts-
Old May 31, 2004 | 08:28 AM
Franklin2's Avatar
Franklin2
If you want to see if the alt is working, check the battery voltage with the truck off, and then check it again with the truck running. The voltage should be higher with the truck running.
seagiant
Electrical Systems/Wiring
13
Jun 9, 2016 05:38 PM
74FordNut
Aug 28, 2015 11:56 PM
esco24
Oct 24, 2009 07:08 PM
highoctane74
24
Oct 6, 2009 10:49 PM
89Bronco_EddieBauer
1978 - 1996 Big Bronco
18
Dec 20, 2003 01:10 AM
