Losing my mind, front shock???
Old Sep 6, 2005 | 03:37 PM
Goobzilla's Avatar
Goobzilla
OK, so I'm finally putting my straight axle back on. I got the spring locating pins lined up with the axle holes and put my 4 degree caster shims in and it's all lined up and good. For the life of me I can't figure out how the front lower shock mounts go back on to the u-bolt. The service manual picture has me even more confused. Anyone got a halfway decent pic of the stock setup assembled? This is for a 55 F-100 BTW. Thanks as always!
Ron
Old Sep 6, 2005 | 06:18 PM
4tl8ford's Avatar
4tl8ford
Ron
It's been a long time since I worked on a newer model like yours. My 48 shocks mount to a pin that goes thru the axel outside of the spring pad.
Hope that giggles the mind a bit
Dick
Old Sep 6, 2005 | 08:38 PM
Fat Fendered Ford's Avatar
Fat Fendered Ford
This might help:
Front axle removal
Front axle restoration
The first link shows the axle from the underside. Hope this helps!
Kevin
1953 Ford F-100
Go Illini
lowzone
Jun 27, 2013 12:55 PM
rdct
Nov 16, 2010 11:26 AM
fordguy622
May 11, 2009 12:17 PM
arapco
Oct 22, 2000 10:51 PM
Ron G.
Dec 6, 1999 05:48 PM
