convert 225mm to 170mm from 2000 F450 front axle?
Hey all,
Peterbilt project hit another snag. Tried converting the 10 lug to 8x6.5 and didnt work. so now i found a 2000 F450SD 8x225mm monotube front axle but just got my hands on a '99 F350 4.10 DRW axle 8x170mm....can i bolt the 8x170 hubs (spacers as its a dually front axle) up front? not sure if the bolt pattern on the rotor will work...ANYONE do this conversion? otherwise i was thinking adapters up front as i can widen the front track abit if i had to, but dont want to go 170mm to 225 adapters out back, as i think its too much weight for those...ideas? suggestions?
thanks
Ron
I will have a front 90 F-superduty 10 lug set up if anyone is interested....
rims and tires too...all 6
thanks
Ron
Going by eyeball measurements...
I think you might be able to swap the entire F-350 dually front spindle/hub assembly (all the way up to the ball joints) over to the 450 monotube axle.
You will also have to use the F-350 rotor as the F-450 rotor won't fit on a F-350 hub. Which of course also means that you'll have to use the F-350 caliper as well.
Good luck. Let us know if the swap works!
fdude64
03-13-2019 03:43 PM
MONAVIERONJON
1999 to 2016 Super Duty
06-06-2017 05:39 PM
