Fender Supports
Old Sep 4, 2005 | 09:02 PM
dongc1's Avatar
dongc1
Fender Supports
On a V-8 truck the radiator is mounted in the rear most set of holes.The front fender supports are bolted on using the same bolts as the radiator. When the radiator is moved forward, as on a six cyl, where do the fender supports bolt. It appears to me that if they are moved forward, they will not bolt up to the fender. Can someone let me know how they go together?
Thanks,
Don
Old Sep 4, 2005 | 09:05 PM
Madathlon's Avatar
Madathlon
what year and model truck?
Old Sep 5, 2005 | 12:05 AM
mtflat's Avatar
mtflat
50 F1 right?
There is a second corresponding hole the same distance toward the front that the radiator moves forward. Should line up just fine.
I can shoot a picture if you need it.
Old Sep 5, 2005 | 12:04 PM
dongc1's Avatar
dongc1
Yes it is a '50 F-1. I have the radiator mounted in the forward set of holes. All is good with that. The problem is the fender brace. On the V-8 trucks they bolted on with the same bolts as the radiator. Where do they bolt to when the radiator is in the forward set of holes? Do they just bolt to the inner fender, using the rear set of holes?
Old Sep 6, 2005 | 12:52 AM
mtflat's Avatar
mtflat
Is there some reason they won't bolt to the radiator brace thru the front set of holes? That way everything would line up just like it does in the V8 - only 2.5" forward.
Old Sep 7, 2005 | 09:44 PM
dongc1's Avatar
dongc1
MtFlat,
The brackets will bolt up as you suggest, but the outside end that bolts to the fender does not line up with the holes. That's what has me puzzled.
Don
Old Sep 7, 2005 | 11:22 PM
mtflat's Avatar
mtflat
Hmmmm, the 49 F3 fenders on my 48 F1 have a bolt that holds the lower fender extension to the upper fender in the right location for the 6 cyl setup. It would mean removing that bolt and attaching the fender support at that hole.
Maybe the F1 fenders are different?
jonf
Sep 3, 2014 09:49 PM
Redgranite_Yooper
Mar 26, 2014 09:57 AM
oscajo
Feb 3, 2014 04:46 AM
18c
Apr 23, 2012 06:20 PM
panningbros
Feb 16, 2010 07:57 PM
