Explorer display won't show up
Old Sep 4, 2005 | 08:08 PM
sandiegogirl's Avatar
sandiegogirl
I have a 98 Explorer XLT. The audio display has completely faded away. I was wondering if anyone else has had this problem, and if it anyone has fixed it at home? I was quoted $400 at a shop, and I think I could do it myself.
Thanks!
Old Sep 4, 2005 | 08:30 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Old Sep 5, 2005 | 09:14 AM
oshoguno's Avatar
oshoguno
If you do a search for blank radio display, radio display or no radio lights you will get a ton of theads on the subject. The short version is that the power supply for the display in the radio was made using cold solder joints, these joints crack and you loose your display. There are many things you can do depending on your mechanical/electrical experience. The radio is easy to get out and take apart. You could replace the board by buying a rebuilt board from any number of places you can find on the web. You can resolder the board yourself if you are skilled with a soldering iron. You can also replace the whole radio with an aftermarket. I resoldered my myself many times and it would last a day, a week or an hour before going back out. I finally did a total and very carefull resolder of every joint on the board and it has been on ever since. If you are not good with an iron then get a replacement board. Do a forum search for the radio display and read some of the hundreds of posts on the topic. Good luck.
Old Oct 1, 2005 | 01:57 PM
hurricanbob's Avatar
hurricanbob
help on its way
go to thread "1998 Ford Exployer Sport-Radio display not displaying"
and see the reply # 9. Click on "on a web site" .
hope it helps, as I plan to use these instructions and give it a try myself.
hurrican bob
Old Oct 15, 2005 | 11:07 AM
hurricanbob
What kind of Radio is it. Cassette or CD? I tried the fix in the previou forum I quoted you, but is was a diff model than what I had. I took it aprt and redid some of the solder joints , but It did not help ( luck for me the radio/cd was still working at least). The week later I tollk it out again and after two hour I found the problem. It was not the same problem with the power supply board , but i found a crack in a joint in the Display board. Redid the joints and BINGO, it now works fine. The display works like new. I did take a pic of the crack solder joint but my daughter has my camera. If you want more info, Let me know . I i can do it , so can you.
1999 F150.
Hurrican bob
Old Oct 17, 2005 | 11:16 PM
Msp541's Avatar
Msp541
If your looking for the radio display fix to be correctly fixed and guaranteed email me and i will help you out i do it on the side and charge $50.00 for the repair.
Good Luck!
78 PEB
Nov 19, 2010 03:35 PM
Truck Issues
Jul 5, 2007 07:19 PM
jack125
May 24, 2007 04:01 PM
madkiwi
Jul 3, 2006 07:21 AM
nishijb
Jun 15, 2006 05:45 PM
