1978 - 1996 Big Bronco
Axle ID
Old Sep 4, 2005 | 06:58 PM
oldbluebronco's Avatar
oldbluebronco
Lightbulb Axle ID
Can Anyone tell me how to read the axle tags on my bronco. maybe a chart or some thing. thanks for anyhelp.
Mark
Old Sep 4, 2005 | 07:02 PM
WhëëlMå1's Avatar
WhëëlMå1
Post up the tag, and we can decipher them for you. That would be the easiest, since Im not aware of a chart made up.
Old Sep 4, 2005 | 09:57 PM
Grogtronics's Avatar
Grogtronics
The second line tells you what gear ratio you have and whether or not it is a limited slip or not. If you have a 3.55:1 ratio with limited slip Diffs it will be writen 3L55
Old Sep 4, 2005 | 10:57 PM
MBBFord's Avatar
MBBFord
What Grogtronics said. L between the gear #s mean Limited slip and nothing means open. Those are basically the only important #s on the tag. The others are build date, build plant, etc... Depending on the year it's either a 8.8 or a 9" rear end, but you don't need a tag to tell you the difference.
Old Sep 4, 2005 | 11:43 PM
Dj300ford's Avatar
Dj300ford
What about the tag it looks like 3L08 8 ??what would that be
Old Sep 5, 2005 | 12:41 AM
94 XLT White/ Silver 302's Avatar
3.08:1 gear ratio, limited slip differential, and it should have 8.8 for ring gear dia.
Old Sep 5, 2005 | 07:27 AM
MBBFord's Avatar
MBBFord
Yep, it's a 3.08 gear set with track lock limited slip.
Old Sep 5, 2005 | 11:05 AM
Dj300ford's Avatar
Dj300ford
I was thinking if u had limited slip and raised the rear of the truck up and were to spin one tire they would the same direction. Mine spin not the same direction. 3L08 8
Old Sep 5, 2005 | 11:17 AM
MBBFord's Avatar
MBBFord
Don't trust that, you must put enough torque to the one tire your spinning to make the clutches lock the 2 together in a %60-40 % lock or so.
Old Sep 5, 2005 | 11:42 AM
oldbluebronco
the front has this:
3.54 V(upside triangle) EDE8TA SC
V(upsidedown triangle) 610310 - 2
the back has:
S817P
3L55 8.8 9D14
So the front is 3.54 and the rear is limited slip 3.55 8.8in
what size is the front axle
Old Sep 5, 2005 | 11:52 AM
MBBFord's Avatar
MBBFord
The front is a D44 30 spline TTB suspension.
Old Sep 5, 2005 | 09:43 PM
oldbluebronco
Thanks for your help
winfordr
Apr 28, 2002 11:54 AM
tryppster
Mar 29, 2002 08:59 AM
mtflat
Apr 8, 2001 07:23 AM
Motorcraftsman
Apr 5, 2000 11:38 PM
jowilker
Jan 28, 2000 03:52 PM
