got the "wierd" thing again... with a code...
Old Sep 5, 2005 | 09:40 AM
  #31
johnny8's Avatar
johnny8
interesting post there "hello"... in my opinion... even if the boost fooler triped up and was stuck open, you would not loose half your boost instantly... the line that that boost is flowing down going to the map sensor is MUCH too small... i believe you may be correct about it causing some of the other codes... but i have not gotten the overboost code since i put that dual valve unit in...
Old Sep 5, 2005 | 06:22 PM
  #32
johnny8's Avatar
johnny8
ok... ran the truck up that hill... 3 times..! no code and no probs... actually i have alternator codes... that doesn't make sense either.. i have a voltmeter and it runs between 13.7 and 13.9 almost all the time... i think the code is getting tripped right after startup... anyway... i'll keep an eye out for that pcm code that i had...
gaut
6.7L Power Stroke Diesel
29
Apr 10, 2024 01:35 PM
wyoclint
Dec 15, 2016 05:02 PM
omar1746
Mar 15, 2016 08:43 PM
broncxl302
Feb 13, 2012 11:55 AM
case2273
Jul 17, 2006 06:40 AM
