got the "wierd" thing again... with a code...
Old Sep 4, 2005 | 08:03 PM
RedStroker6's Avatar
RedStroker6
good deal. i had been thinkin, ya know, if its done it before loaded, and now unloaded....its GONNA do it again....let us know.
Old Sep 4, 2005 | 08:05 PM
touchofgrey's Avatar
touchofgrey
Originally Posted by johnny8
man... you read my mind... gonna do that tommorow...!
The way my luck runs........if I did it......it wouldn't fail. LOL
Old Sep 4, 2005 | 08:08 PM
johnny8's Avatar
johnny8
i tried to duplicate the problem on the way home and no dice.. but i wasn't on the same hill... no prob though.. that hill is only a few miles from my house...
Old Sep 4, 2005 | 08:37 PM
johnny8's Avatar
johnny8
hey guys... i was reading some things online about this... could this be the "limp" mode that the pcm triggers when it senses the tranny slipping...?
Old Sep 4, 2005 | 08:49 PM
touchofgrey
We can speculate a long time without the code.
Old Sep 4, 2005 | 08:52 PM
johnny8's Avatar
johnny8
true... i hope this isn't the problem.. but i wonder.. it only happens when i'm in overdrive... and it only happens when i am under load going up a hill at low rpms.... hmmmmm those would be the mostly likely time for a tranny to slip...
Old Sep 4, 2005 | 08:59 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
The tranny probably wouldn't leave a PCM code. It would likely manifest itself as a blinking OD light. Does it shift really hard when the power is down...like, snap your neck hard.
I'm wondering now if you aren't having problems with an injector harness or the IDM.
Old Sep 4, 2005 | 09:04 PM
johnny8's Avatar
johnny8
i have the sonnax kit, and the shifts are very firm... the only shift that is soft is when the torque converter locks up.. under acceleration the tc is a little sluggish but it is a stock tc with 94k on it...
if it is a problem with a harness or the IDM, (what is that?), why does it only happen under specific conditions... wouldn't a harness problem occur at different times, you know, it would just happen whenever...?
Old Sep 4, 2005 | 09:07 PM
johnny8's Avatar
johnny8
one other thing... a tech post that i read said there was a pcm code associated with a blinking od light and the code meant the pcm sensed the tranny sliping and went into "limp" mode... that's why i posted one of my previous questions after i read that..
Old Sep 4, 2005 | 09:10 PM
johnny8's Avatar
johnny8
the code on that post was a "P1728"...
Old Sep 4, 2005 | 09:19 PM
cookie88's Avatar
cookie88
FTE Emeritus
Does that code look familiar? The "PCM" codes are P0603, P0605....down in that range.
IDM is injector driver module....and it would be intermittant like a harness, but might also be susceptible to external electronic interference. The only reason I mentioned it is because of the amount of power loss....like a bank of injectors shut down or something. Any sort of "normal" defueling situation you don't experience a power loss, it just levels off at that point.
Old Sep 4, 2005 | 09:26 PM
johnny8's Avatar
johnny8
that's why i was wondering if this is a "limp home" setting... it isn't a regular defuel, and i don't think it's a bank of injectors loosing power... this is definately "load" related... that's what makes me wonder about the tranny code...
Old Sep 4, 2005 | 09:34 PM
  #28
cookie88's Avatar
cookie88
FTE Emeritus
Well, like touchofgrey said, it's all guesswork until we get that code again. I don't know enough about the transmission electronics to make a SWAG.
Old Sep 4, 2005 | 09:48 PM
  #29
johnny8's Avatar
johnny8
i'll post on this thread tommorow... i'll spend some time and see if i can get the code, and i'll watch the o.d. light to see if it blinks... that code does look familar... i think that might be the code that came up... i hope not though.. i don't have the money for a new tranny... have a good night..!
Old Sep 5, 2005 | 03:57 AM
  #30
Hello's Avatar
Hello
I don't know what your code is yet, but my thoughts and results may interest you.
Can a double boost relief valve not working correctly? Can it be blowing off too much boost all at once showing much less psi all of a sudden at the MAP sensor so you have a sudden loss of performance, or can it not blow enough boost to cause defueling. For me, I switched out my BRV for a ITP boost regulator which works perfect on their stock setting but is also adjustable. Now I only get the P1211 code, which is a code Diablo can't get rid of and is normal for their tuning, whereas before I got a couple more other codes P0238, P0478. This all using the Predator on 100hp running empty.
I also think the Predator still uses a lot of the OEM safeguards to protect the engine and us, like the speed limiter to match the speed ratings of our tires. For me at WOT on a roll at 80mph, it goes like crazy up to 30psi and starts to defuel at 90mph to 15psi and maxes out at 100mph. Whereas the chips I heard, can be programed to bypass these controls altogether. But I'm keeping my Predator just to keep me and my engine on the safe side.
