Tornadoe Fuel Saver
Old Aug 24, 2002 | 12:23 PM
irjpr's Avatar
irjpr
Tornadoe Fuel Saver
Old Aug 25, 2002 | 12:42 PM
wolfman81's Avatar
wolfman81
Tornadoe Fuel Saver
I seen a ad on TV about this...you just sit it on top of the carb in the breather...They said that their product increases airflow to carb.anyone seen this or have an opinion ...Thanks Dave
Old Aug 25, 2002 | 02:53 PM
hawkrod's Avatar
hawkrod
Tornadoe Fuel Saver
snake oyl products for sure. if it worked it would have a carb approval number and be required by law. these crappy cheap gimmicks have been around since the 30's and still don't do any thing. sorry don't know how to make a bronx cheer sound in type! hawkrod
Old Aug 25, 2002 | 04:02 PM
Torque1st's Avatar
Torque1st
Posting Legend
Tornadoe Fuel Saver
Trash, just like the fuel line magnets. There are several discussions on those devices in this and other forums, use the <SEARCH> function to find them.
Old Aug 26, 2002 | 03:54 PM
85351ho's Avatar
85351ho
Tornadoe Fuel Saver
TRASH, you might as well drop some cash down in your carburator, itd do about the same as a tornado
Old Aug 26, 2002 | 06:49 PM
sparky's Avatar
sparky
Tornadoe Fuel Saver
What next you are going to tell me that I can't run my engine with no oil just because I used Slick50
Which brings up the question since that stuff "chemically bonds to the metal" how does it know what metal not to bond too?
Sparky
Old Aug 26, 2002 | 07:19 PM
FE427TP's Avatar
FE427TP
Tornadoe Fuel Saver
http://www.higginsfordperformance.com/dynotest.htm
Old Aug 27, 2002 | 12:25 AM
trinogt's Avatar
trinogt
Tornadoe Fuel Saver
Ha hah! Product oops! Thanks for that! Good to see independant tests done on a miracle product like that!
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Aug 27, 2002 | 01:59 AM
Torque1st's Avatar
Torque1st
Posting Legend
Tornadoe Fuel Saver
That Tornado unit seems to be a good start on designing a restrictor plate! -hehe
If spinning the air worked the automakers would have designed in swirl plates a long time ago. They can do most anything when they control all the molds and tooling, for very little cost / unit.
As far as oil additives go... My Uncle that worked as an Engineer at a Ford plant once told me that if an additive worked it would already be spec'd to be in the oil or fuel. The Automakers will do most anything to squeeze out another 0.01 MPG on the CAFE standards, as long as it sells :-)
All of those teflon particles get filtered out by a decent oil filter.
By chemicly binding to all of the parts, it binds the engine together so it gets unlimited mileage, -while being towed back to the shop
Apr 13, 2004 12:08 AM
Nov 12, 2002 01:38 AM
Jan 14, 2002 09:06 AM
Mar 11, 2001 10:13 PM
