Starting problems
Old Aug 24, 2002 | 11:57 AM
Ford460BBpower's Avatar
Ford460BBpower
Starting problems
I have a engine that u have to pour gas down in the carb to get it cranked. The carb is an electric choke edelbrock 600 cfm.
Old Aug 24, 2002 | 12:23 PM
irjpr's Avatar
irjpr
Starting problems
you want some help, we need more info....
Old Aug 24, 2002 | 12:43 PM
Mil1ion's Avatar
Mil1ion
Starting problems
Pouring gas down the carb has nothing to do with cranking the engine.
The things that allow for cranking an engine are:
The battery ,wiring,Ignition switch,wiring to starter solenoid,Starter solenoid,Starter Drive,Starter.
You need to be more specific with your situation if you want specific answers.
http://www.clubfte.com/users/mil1ion/2cents.gif
[font color=red]Dennis
FTE Assistant Administrator
[/font]
[link: motorhaven.autoanything.com|How YOU Can Support This Site]
http://www.clubfte.com/users/mil1ion/canada_flag_animated.gif
[link:www.clubfte.com/users/mil1ion/Mil1ion.html|My Website,"North Of The 49th"]
[link:www.ford-trucks.com/guidelines.html|Club FTE]
http://www.clubfte.com/users/mil1ion/Minimorleytruck.JPG
[font color=blue]78 F-150 429CJ,Silver,Explorer Pkg.
64 1/2 Mustang Pre-World's Fair Car #8092
68-Mustang 289 2v-Sunlit Gold
[/font]
Old Aug 24, 2002 | 12:54 PM
79f3504x4's Avatar
79f3504x4
Starting problems
Sound like no fuel delivery;bad pump,clogged screen in tank,collapsed rubber line,no fuel in tank.Brian
Old Aug 24, 2002 | 08:35 PM
Ford460BBpower
Starting problems
U can turn the engine over repeatedly but until u pour gas down the carb it wont start.
Old Aug 24, 2002 | 09:35 PM
Mil1ion's Avatar
Mil1ion
Starting problems
Just like 79350 says:
Fuel delivery problem
Carb,Filter,pump,line,tank.
MY guess is the fuel pump.
[/font]
[/font]
Old Aug 26, 2002 | 11:36 AM
73Custom's Avatar
73Custom
Starting problems
Old Aug 27, 2002 | 12:21 AM
trinogt's Avatar
trinogt
Starting problems
Look down the carb throat and pull on the accel linkage. Watch for gas squirting out of two little jets. That is your accelerator pump causing that. If you see no gas, might be time for a rebuild, or remove carb and clean, check for any blockage in those two jets.
Mark
https://www.ford-trucks.com/user_gallery/displaythumbnail.php?&photoid=5362&.jpg
Ford started it; Ford will finish it!
Old Aug 27, 2002 | 08:06 AM
76supercab's Avatar
76supercab
Starting problems
Is the choke plate closing when cold?. Could also be a fuel pump going bad. If after cranking you don't see fuel coming out of the accelerator pump nozzles when you open the throttles I would suspect the fuel pump. It's an easy way to tell if there is fuel in the fuel bowl of the carb. If you have fuel coming out of the accelerator pump before you crank then I suspect that the choke isn't closing enough. The only other thing I can think of is very low compression (worn out rings) in the engine. Do a compression test on the engine.
460powa
20
Dec 24, 2010 05:49 AM
rodweldz
Oct 7, 2009 02:46 PM
old_man_winter
Sep 21, 2006 04:35 PM
pmc
Dec 16, 2005 10:43 AM
hotbbb
Jan 30, 2004 11:55 AM
