rough cold starts
Old Aug 28, 2005 | 10:46 PM
dorkpunch's Avatar
dorkpunch
rough cold starts
any suggestions? starting her up if shes been sittin awhile is a challange, takes three or four tries of pumping/cranking/feathering the pedal and having her die before she will finally catch. Choke (manual) doesnt seem to make a difference if it is on or off. '70 360 f-250 cs. Thanks all!
Old Aug 28, 2005 | 10:47 PM
ford390gashog's Avatar
ford390gashog
set the fast idle to about 1,500 rpm
Old Aug 28, 2005 | 11:07 PM
elemint's Avatar
elemint
Mine did the same thing but rebuilding the carb and advancing the timing helped a lot.
Old Aug 28, 2005 | 11:14 PM
dorkpunch's Avatar
dorkpunch
I rebuilt the carb and that helped some- still have the rough cold start and once its warm and sits for an hour it tends to flood- hold the pedaly down and crank for 10 secs and she fires right up. havent played with the timing yet though....
Old Aug 29, 2005 | 07:51 AM
4Cammer72's Avatar
4Cammer72
youve got fuel leaking from the carb somewhere. recheck alll your bolts on the carb, you probably have a loose one or two . especially check the accellerator pump bolts.
Old Aug 29, 2005 | 09:03 AM
1975Ford's Avatar
1975Ford
When you rebuilt your carburator, did you soak the carb parts in a cleaner for a few hours?
Replace the carburator.
Old Sep 10, 2005 | 02:59 PM
Franken-ford's Avatar
Franken-ford
ahh never mind... I re read the post more carefully/ i think its leaking out of the floatbowl, possibly a combination of that and/or mechanical fuel pump maybe starting to go?
you probably have it fixed already...
Last edited by Franken-ford; Sep 10, 2005 at 03:04 PM. Reason: mis read the post / gave wrong idea
rbloodhound
Louisiana Chapter
23
Sep 4, 2016 02:49 PM
DISLFVR
25
Jun 19, 2016 05:12 PM
Newby87
33
Feb 26, 2016 12:35 PM
fontainesurvey
6.7L Power Stroke Diesel
Oct 30, 2010 01:37 PM
