Sponsored by: Auxito
99 Supercab
Old Aug 28, 2005 | 11:14 AM
RA022323's Avatar
RA022323
5th Gear
Question 99 Supercab
Hello to everyone
I am havind a problem with the illumination of the odometer. At times it gets dim and even goes out all together. Pushing and allowing the reset to snap back sometimes corrects the problem, or there may be no problem for several days at a time. The Ford manual has no in depth info on this problem.
Hope someone can help.
Old Aug 28, 2005 | 07:01 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
...Welcome to Ford Truck Enthusiasts! Take a moment to read the Guidelines, it will help you to navigate through and understand this site.
Stick around someone will be by shortly to answer your question.
We are happy you have chosen the best source for Fords!
Enjoy FTE....and
JOIN CLUB FTE -SUPPORT THE FORUMS!
…..See you on the boards.
Moved and member notified
Old Aug 28, 2005 | 07:55 PM
triton_2002's Avatar
triton_2002
Originally Posted by norton
Hello to everyone
Welcome to FTE!
This is a somewhat common problem, with a little work it can be fixed. Here's how:
https://www.ford-trucks.com/forums/s...25252Bblackout
Old Aug 28, 2005 | 08:51 PM
steve(ill)'s Avatar
steve(ill)
i just pulled the instrument cluster this morning and disassembed the circuit board and soldered the cold joint on the back. takes about an hour or little more if you know what you are doing. dakotas photos help a lot. getting the cluster out of the dash is the hardest part and that aint too bad.
Old Aug 29, 2005 | 07:53 PM
RA022323's Avatar
RA022323
5th Gear
Hi Steve (ill)
Read the thread by dakota - viking and all replies. I see i'm not alone on this problem.Thanks for steering me in the right direction. Will probably make the repair this weekend.
agferna
Jan 9, 2008 05:36 PM
hdfxrusa
New Hampshire Chapter
Jan 2, 2008 09:02 AM
xnman
Aug 17, 2007 10:46 PM
78workhorse
Pennsylvania Chapter
Oct 22, 2006 09:54 AM
150 flareside
Jul 4, 2004 06:58 PM
