91 f150 truck has no power want move
changed ignition module truck started great went for a ride everything good.
truck is low on antifreeze topped it up. thik i needd a new thermastat truck started to over heat and started to loose power pulled it over let sit for couple hours stated it again it will move but has no power . what do i check have no idea completely lost. checked oil no extra fluids in it..
There are two ways of setting the timing. Use a timing light (the right way), or set it until it idles alright, and test drive it. Keep advancing the timing, a bit at a time until it starts pinging when engine is under load and then retard it a tiny bit (this is the redneck way). Timing light is the best way. ...Terry
conderd
12-29-2010 09:31 PM
