programer and a chip
Old Oct 13, 2005 | 07:05 AM
twildman's Avatar
twildman
If the Ford Tech knows what to look for the tuner's leave a trace, depends on the mood they tech is in as to whether or not he says or notes anything about it.
Old Oct 13, 2005 | 07:52 AM
Kwikkordead's Avatar
Kwikkordead
Originally Posted by cookie88
If the warranty is of prime concern you might want to leave it stock. The problem is the only way to safely run any power enhancing device on a tow vehicle is to lay the groundwork. Namely a larger than stock exhaust, improved intake, and a set of gauges (pyrometer, boost, trans temp) to monitor it. These things are a tip off to look for a power enhancer.
As far as the best solution for your rig....I'd go with a hand held programmer like the Diablo Predator on the tow (lowest) setting. Once the performance tune is set back to stock it leaves no traces.
This is the route that I took with my truck. It's past warrenty now, but I wanted to make sure that it would last for many years to come. The Diablo Predator tow setting is perfect for me. Lot's of extra power and no smoke at all.
Scalemandave
1997 - 2003 F150
Apr 28, 2011 09:37 PM
c.wathen
Dec 24, 2010 01:27 AM
abclean
Mar 17, 2008 10:16 PM
eric777
13
Mar 16, 2006 06:18 PM
Pastmaster
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Apr 21, 2000 08:13 PM
