View Poll Results: Do you use a fuel additive?
Yes, always
95
54.29%
Occasionally
59
33.71%
Never
21
12.00%
Voters: 175. You may not vote on this poll
Fuel Additive Poll
Old Aug 27, 2005 | 12:52 PM
kw5413's Avatar
kw5413
Unless you plan on going to Flagstaff in the winter...Or even up on Mt. Lemon on an unsually cold Tucson day...
Old Aug 27, 2005 | 12:58 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
I've been using Howe's Lubricator only in winter for gelling. Has worked well...no gelling. As I just got this '05 PSD, none for it yet. Had a '92 7.3 I've used it in.
Old Aug 27, 2005 | 03:59 PM
cathlabdog's Avatar
cathlabdog
I use power service in white bottle year around , its the only thing wally world sells here in flagstaff az. lie-o-meter says 19-20 mpg ave town/hwy 16 in town, hand calc shows 15-17 actual . use it for the lubricity for injectors and water in fuel , since day one and no pblms after 20k.
Old Aug 27, 2005 | 05:17 PM
clevelandjim's Avatar
clevelandjim
How much Power Service do you use? I use 16oz per 40 gallons.
Old Aug 27, 2005 | 05:26 PM
emilbanks's Avatar
emilbanks
I use Howes a double shot glass in every tank summer & winter use it on all my diesels for years.
Old Aug 27, 2005 | 05:50 PM
kw5413's Avatar
kw5413
0.64 oz/gal of fuel @ fuel up....give or take.
Old Aug 27, 2005 | 05:52 PM
tinytrixie's Avatar
tinytrixie
I use PS also every fill up. I probably use too much, but what the heck. I love this truck so I really watch the fluids & do what I can to keep it running like new. Does not use a drop of oil between changes, and my mpg seem up about 1/2mile/gallon w/PS. I just consider that a beneficial side effect!
Old Aug 27, 2005 | 06:01 PM
cathlabdog's Avatar
cathlabdog
3 oz per 10 gals +-, as per power service recomendations on the bottle.
Old Aug 27, 2005 | 07:01 PM
bedwards's Avatar
bedwards
Skeptical at first but since I got a batch of Critters in my tank and had to treat them have been using the Powerservice gray bottle. I have about a .7mpg increase since I started using it and its consistent, stop using it and the mileage goes down. I figure this will pay for itself when you figure in the extra lubrication properties.
BE
Old Aug 27, 2005 | 10:40 PM
kw5413's Avatar
kw5413
That will only increase your cetane rating by 3 points. To increase by 6 points (which I recommend) you would add 0.64 oz/gal or 6.4 oz / 10 gal.
Keep in mind that the average cetane rating, at the pumps, in the US is 43. Rumor has it that the Ford version of the 6.0 is designed for fuels with a 46+ cetane rating. Why take a chance that you are buying 41 cetane?
Please note the following from the grey bottle I buy as well as the Power Service web site:
<TABLE cellSpacing=0 width=520 border=0><TBODY><TR><TD width=504 colSpan=2>Part No. 3016
For peak engine performance and desired cetane boost, add each time you refuel at the following treatment ratios:
<TABLE cellSpacing=1 cellPadding=2 width=250 border=0><TBODY><TR><TD class=productcharttext align=middle width=130 bgColor=#ff0000>Cetane Boost
</TD><TD class=productcharttext align=middle width=152 bgColor=#ff0000>16-oz Treats:
</TD></TR><TR><TD class=producttext align=middle width=130>3 Numbers
</TD><TD class=producttext align=middle width=152>50 Gallons
</TD></TR><TR><TD class=producttext align=middle width=130>6 Numbers
</TD><TD class=producttext align=middle width=152>25 Gallons
</TD></TR></TBODY></TABLE></TD></TR><TR><TD width=504 colSpan=2>
Part No. 3025
</TD><TD class=productcharttext align=middle width=152 bgColor=#ff0000>32-oz Treats:
</TD><TD class=producttext align=middle width=152>100 Gallons
Part No. 3041
<TABLE cellSpacing=1 cellPadding=2 width=250 border=0><TBODY><TR><TD class=productcharttext align=middle width=128 bgColor=#ff0000>Cetane Boost
</TD><TD class=productcharttext align=middle width=154 bgColor=#ff0000>96-oz Treats:
</TD></TR><TR><TD class=producttext align=middle width=128>3 Numbers
</TD><TD class=producttext align=middle width=154>300 Gallons
</TD></TR><TR><TD class=producttext align=middle width=128>6 Numbers
</TD><TD class=producttext align=middle width=154>150 Gallons
Old Aug 27, 2005 | 10:54 PM
clevelandjim
Actually, Power Service is a little addicting for the less engine noise while cruising and less exhaust smell while idling. I use a whole 32oz bottle for my 40 gallon fill up towing, but I usually use 16oz around town.
I'm also hoping I avoid EGR clog-up using the stuff.
Old Aug 27, 2005 | 10:58 PM
kw5413's Avatar
kw5413
It will certainly help...along with a CI-4+ rated oil.
Old Aug 28, 2005 | 04:55 PM
  #28
Z-MAN's Avatar
Z-MAN
Summer Months I Use Lucus Fuel Treatment, Winter I Use Howe's Or P/s
Old Aug 29, 2005 | 09:13 AM
  #29
Skweeker's Avatar
Skweeker
I use Power Service in roughly the same amount as kw5413 indicates.
Old Aug 29, 2005 | 02:16 PM
  #30
reinforcer's Avatar
reinforcer
I guess I'm lucky! The station where I fuel has designated one of thier tanks to be premium diesel. I asked them what made it premium and they showed me that it is the same diesel as their other pumps with the onsite addition of valvetech(spelling?) additive. The advertised cetane rating is 50 and the engine runs much quieter than before. I have not noticed an improvement in milage. They charge 4 cents per gallon more for the premium and I do not have to mess with adding it myself.
