choke housing
Old Sep 7, 2002 | 06:17 PM
supercab4x4's Avatar
supercab4x4
choke housing
does anybody know where the metal tube from the choke housing is supposed to go and where i might find one?mine is rusted and busted off.also why does my 76 have electric choke and my 78 have this tube running to it.thanks for the replies
Old Sep 7, 2002 | 06:33 PM
LxMan1's Avatar
LxMan1
choke housing
What size engine?? My other 77 F100 302 2bbl, the tube went straight into the passenger side exhaust manifold.
Old Sep 7, 2002 | 09:04 PM
supercab4x4
choke housing
its a 460
Old Sep 9, 2002 | 10:18 PM
LxMan1's Avatar
LxMan1
choke housing
Did it not go into a plate on the manifold under the choke area? One tube that was threaded into the carb and the other one hooked up to the carb via a vacuum line in on the top rear of the carb?
Old Sep 9, 2002 | 10:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
choke housing
If your "choke stove" is rusted out and you can't get a replacement there is a discussion on how to make a new one in the Garage Forum.
Old Sep 10, 2002 | 07:53 PM
bigf150's Avatar
bigf150
choke housing
Old Sep 10, 2002 | 08:13 PM
Polkat's Avatar
Polkat
choke housing
My '73 has the choke tube as well, and it goes to a connection at the back of the passengers side exhaust manifold. I don't know if this was stock, but the choke works fine. Polkat
Old Sep 11, 2002 | 03:30 PM
hartmark's Avatar
hartmark
choke housing
I found some good info in a couple of threads from earlier this year (or maybe last).
[Link:www.ford-trucks.com/dcforum/61_79/9124.html|message 9124]
[Link:www.ford-trucks.com/dcforum/61_79/9013.html|message 9013]
There is a couple of good links for what you need to fix it.
Mark
Old Sep 11, 2002 | 04:17 PM
cjcathey2002's Avatar
cjcathey2002
choke housing
when i had the stock manifold on i busted the choke tube when i did a carb rebuild. my plate was too badly rusted to reuse so i went and bought a repair kit from napa. i fabricared a plate out of 1/4 steel. thin i justed used blue rtv to seal up the new plate and the maifold, i put the big thing in the kit in the plate i fabricated, you have to see the kit to understand what i mean. i think you just drill like a 1/2 hole, maybe more maybe less in the new plate and the big thing taps itself into the plate, there was no air leaks and the tube just drops down into it. email me and i will try take a picture of it this weekend
1977 F250 460
C6 Hedman Headers
Dual 40 series
edelbrock performer
holley 4160
msd 6a and blaster coil
J.McConnell
Jan 22, 2016 02:37 PM
1986F150six
43
Mar 1, 2015 06:24 PM
74 f100 ranger
Jan 12, 2002 12:06 PM
4fords
May 15, 2001 11:14 PM
