Starting Procedure PSD
Old Aug 26, 2005 | 06:50 AM
Glockem45's Avatar
Glockem45
Question Starting Procedure PSD
I had a question about the starting procedure on my 2004 F-350 PSD CC. Anyways, this is my first Diesel, however my diesel experience comes from my dads truck. He still has his Ford 1985 F-250 6.9 Diesel International Harvester motor.
His glow plugs have to warm up and a light on the dash will come on and go off. Then you start the truck. I was wondering about these new trucks, what is the correct procedure? I read the owners manual and it mentions an electronic glow plug system. Does this mean I just crank the ignition, or do I have to wait for the plugs to warm up like my dads truck? I don't see any light on the dash that indicates glow plugs.
Since I have had the truck for the last week, out of habit, I turn the key and let the truck set for about 5-10 seconds and then hit the start with the key. the truck usually cranks for about 3-5 seconds and then turns over. Is this normal or what? Thanks guys.
Old Aug 26, 2005 | 07:12 AM
05_F250's Avatar
05_F250
Yes there is a indicator on the dash that will go out when it is time to start.
On mine it looks like 2 loops.
Old Aug 26, 2005 | 07:49 AM
Beachbumcook's Avatar
Beachbumcook
Got Diesel?
Yes, you must wait... the indicator is the "two loops" that light up and mentioned above.
In the summer, it warm up very fast (1 - 2 seconds or less). In the dead of winter, it may take 3 - 5 seconds.
Turning the key until the light goes out will enure a "start" when cranking. If you try to soon, the motor will turn over, but there is not enough energy to pre-heat the glow-plug and fire the injector.
The circut will stay on after turning the key, so "cycling" two times in the dead of winter does not help. Just turn it once and wait the full time and you will be fine!!
Use diesel fuel additives year round and anti-gel in the winter (all the time) and you will be trouble free!!!
Good luck and enjoy.
Old Aug 26, 2005 | 08:23 AM
vwp6269's Avatar
vwp6269
I heard from a buddy of mine that works at my off-road shop that the new 06's done have a glow plug light you just turn the key.
Old Aug 26, 2005 | 08:33 AM
dana_wildcat's Avatar
dana_wildcat
not true, the 06 has a light just like the others....its in the center of the cluster now instead of off to the right like the 04 was
glockholiday
16
Aug 11, 2014 10:30 AM
GlennSwett
144
Mar 13, 2014 11:08 AM
timcos
Sep 10, 2008 10:57 PM
lawmans3
Oct 14, 2007 11:00 PM
Ace of Spades
Aug 8, 2004 01:29 AM
