Over drive or not?
Old Aug 25, 2005 | 05:30 PM
G-Bone's Avatar
G-Bone
Over drive or not?
Just got ourselves a 2001 F350 Lariet 4x4 crewcab 7.3 turbo.....blah, blah.
We are moving up from an F150.
Both w/auto transmission.
I was always told, when towing, to always disengage the auto-overdrive
on my old F150. Does this hold true for the F350 as well?
I'm doing my first trip tomorrow up into the high desert and the sierras.
and I need to know.
Thanks
Old Aug 25, 2005 | 05:56 PM
kingfish51's Avatar
kingfish51
No need to shift out of overdrive unless it keeps hunting for the right gear or you are going up and down hills. I used to drive with overdrive on in my 150 when I towed my boat. Owners manual stated to leave it on except for the conditions I stated above.
Old Aug 25, 2005 | 08:42 PM
Beast12's Avatar
Beast12
You will want to turn overdrive off. Not good for the transmission. Not worth the few dollars in gas savings when you need to get a rebuild.
-Matt
Old Aug 25, 2005 | 09:07 PM
JOE-M's Avatar
JOE-M
I agree with kingfish51. If it's not hunting back and forth between gears or feeling like it's bogging down, keep it in overdrive.
Joe
Old Aug 25, 2005 | 09:10 PM
RedTaurus94's Avatar
RedTaurus94
A wise man told me to lock out the OD at speeds under about 60 MPH. I used this method and am totally happy with it. I was worried that my 4.10 gear would turn too many RPMs, and it would if I stayed out of OD at 70 MPH. I just lock it out until I get her wound out to about 60, and it works just great. Most definitely you need to be out of OD before your truck's tranny starts searching for a lower gear as you are slowing down. Just remember that extra heat will be generated in your tranny if you don't and heat is the death of a transmission.........
Old Aug 25, 2005 | 09:11 PM
7DF250's Avatar
7DF250
I towed in overdrive with my 97, just carefully, only on a downhill or flat land and could hold speed without "lugging" it, prob 95% with it off though.
Old Aug 25, 2005 | 11:42 PM
bocomojoe's Avatar
bocomojoe
G-Bone, if you are towing the same trailer that you were towing with your 150, I agree with Kingfish, as long as the tranny isn't "hunting" leave it in OD. My '96 F-250 had 3.55's and when I sold it it had about 190,000 mi and no problems. 120,000 mi or so of the 190K was pulling a 5-W. Does your F-350 have 4.10 rear dif? How many mi on your F-350? If you haven't had the tranny serviced or if you don't know when it was last serviced you should have it serviced, compete fluid change. About the only time I would lock out OD would be on long grades of maybe 5% and above. But usually if I hold the fuel feed down the tranny is pretty good at staying in gear without "hunting". Have fun camping.
Old Aug 26, 2005 | 06:07 AM
jowilker's Avatar
jowilker
I asked at the tranny shop last spring when I had my AOD rebuilt, and was told as long as it was pulling in OD and not shifting in & out that towing in OD was OK.
John
Old Aug 26, 2005 | 03:17 PM
andym's Avatar
andym
To throw my two cents in...
The reason that some people recommend it is that when towing a load some vehicles hunt between gears. If the driver lets it happen for too long, it will burn up the tranny very quickly. To cover their behinds, manufacturers have always said lock it out of OD when towing.
The reality, of course, is that you have to use common sense and good judgment. As long as your tranny is not hunting back and forth, using overdrive is fine. It will not harm the tranny at all.
Old Aug 29, 2005 | 08:22 AM
Casey's Avatar
Casey
Ford doesn't. If you read the owner's manual it says what most here are saying, tow in overdrive unless it is frequently shifting.
Old Aug 29, 2005 | 02:13 PM
KarenLynnAQHA's Avatar
KarenLynnAQHA
I just traded in your exact truck and i hauled a very heavy 38' horse trailer. I did what every one else suggested. I took it out of OD only if it was gear hunting or i knew conditions were such that it soon would be.
Reddman
Oct 8, 2013 05:25 PM
ItsMREMT
S. California Chapter
Jul 14, 2011 02:49 PM
slim_falcon
Offroad & 4x4
Aug 11, 2004 01:26 PM
ecajberry
Jul 3, 2004 11:06 AM
