Offroad & 4x4
2wd upgrade
Old Aug 9, 2004 | 04:01 PM
slim_falcon's Avatar
slim_falcon
2wd upgrade
what would it take to upgrade my ol late 80's f-150 to 4x4? ive already gotto get a new tranny, so transfer case, drive shaft, axles, blah blah blah's all no problem, i just need to know what to use with what? which tranny, transfer case combo?
Old Aug 9, 2004 | 05:23 PM
teds74ford's Avatar
teds74ford
For ease, I would suggest getting the TTB out of a truck, and the tranny, x-case and driveshafts. For a good offroad-oriented truck, get a T18/205 combo and a dana 44 out of a 70s truck. Of course, the driveshafts won't line up, and the mounts will have to be custom. How do you plan on using it, and with what size tires?
Old Aug 9, 2004 | 07:17 PM
slim_falcon
off-road
mostly as a daily driver, but on the weekends i want a beast of a 4x4 ready to go at the push of a shifter, ive got some 31x12's for the rear and some 31x10.5's for the front.....
Old Aug 9, 2004 | 07:40 PM
teds74ford's Avatar
teds74ford
If that is all the bigger of tires you want to run, I would go with a stock TTB setup. The more stock, the easier to swap in and less custom fab work.
Old Aug 9, 2004 | 09:31 PM
slim_falcon
id like to keep it perty stock overall i just want some serious 4x4 power n traction. would it be possible to keep the same tranny and just get a shorter driveshaft to accomodate for the transfer case? maybe a lift to make room for the solid axle up front?
Old Aug 9, 2004 | 09:40 PM
teds74ford's Avatar
teds74ford
As far as the driveshaft, that is why I said to get all the stuff from parts truck. Sure, you can lift it to clear a solid axle, but I don't know how high you have to go to make it work. For running 31s, you don't need to lift too high, so it might look weird with 8" lift and 31s. If you are going to keep it relatively stock, I would just get the TTB stuff. You can pick up the front axle pieces, driveshafts, tranny and transfercase, and slap it all in. I think there was something in the tech articles about this conversion. Good luck, Ted
Old Aug 9, 2004 | 09:45 PM
slim_falcon
i just wanna lil lift so i dont have to worry bout clearance or rubbin when im rompin through a big hole. preciate all yalls help...
Old Aug 9, 2004 | 10:16 PM
slim_falcon
tech
i found the article, it details everything from suspension to steering to axle ratio, thanks
Old Aug 10, 2004 | 02:55 PM
teds74ford's Avatar
teds74ford
No problem. Hey, get some pics up when you can.
Old Aug 11, 2004 | 01:26 PM
slim_falcon
sure thing...
bsquash
Testing.....
Jan 27, 2013 10:16 AM
hagerty_justin
Feb 5, 2011 07:12 AM
Sn0wMan
Jul 9, 2004 11:50 PM
