new carburator
Old Oct 4, 2005 | 11:58 AM
  #31
mdmbkr's Avatar
mdmbkr
Thanks for that info, sounds like the DP is what I want also.
Old Oct 7, 2005 | 03:08 PM
  #32
WoomaHodal's Avatar
WoomaHodal
Will the C series use more gas than the DP ones?
Old Oct 12, 2005 | 01:37 PM
  #33
BigBear1's Avatar
BigBear1
I found these descriptions on www.summitracing.com they may or may not be helpful.
More power across the rpm range.
Offenhauser Dual Port intake manifolds feature completely separate runner systems for the primaries and secondaries. At low-load, the primaries feed the fuel-air charge through the smaller bottom passages at near sonic speed, improving power and efficiency. When the secondaries open, their charge goes through the bigger, cooler upper passages. Then, in turn, it is rammed into the cylinders when it encounters the high-velocity mix from the primaries. The result is better fuel economy and a 15-30 percent power increase across the whole rpm range.
Added muscle for small cars and pickups.
Offenhauser C Series intake manifolds fill the gap between stock and competition setups for 4 and 6-cylinder cars and pickups. They improve torque in the mid and upper ranges, with power bands that span from 2,500 rpm to more than 7,000 rpm. Smaller applications use Holley 5200 or Weber 32/36 series 2-barrel carbs. Holley 2300s can be used for competition with an adapter. Six-cylinder, 4-barrel versions can use square bore Holley or Carter carbs. Emission-control provisions can be blocked off for competition.
Old Oct 12, 2005 | 10:56 PM
  #34
Mark-I6's Avatar
Mark-I6
i did a swap out two weeks ago, and i used the C-series offy intake, and an edlebrock 4 barrel cab. i have seen a huge gain in power across the board and i have a vacuum leak. i cant wait till i find and fix it so i can tune things right and get the whole affect oh and i am getting around 12 mpg.
Old Nov 14, 2005 | 02:58 PM
  #35
BigBear1's Avatar
BigBear1
Finally!!!!!!!
Got my Offy DP Friday (11/11/05) from JEGS, a month earlier than they said it was going to get here I still had to wait a long time though I can't wait to get it on!
Old Nov 14, 2005 | 04:16 PM
  #36
srercrcr's Avatar
srercrcr
12 mpg? I thought they said "better fuel mileage"!
Old Nov 14, 2005 | 04:45 PM
  #37
WoomaHodal's Avatar
WoomaHodal
I'm getting around 12mpg also
i have the single barrel carter carb though
Old Nov 14, 2005 | 11:33 PM
  #38
Mark-I6's Avatar
Mark-I6
the reason that i was/am only getting 12mpg is because i have a vacuum leak so i can not adjust the carb properly. That was also when i had first done the swap and was playing with it. Now i am getting about 15 but i still have a pretty big vacuum leak.
Old Nov 15, 2005 | 09:00 AM
  #39
WoomaHodal's Avatar
WoomaHodal
i dont have any vacuum leaks. i think my low fuel economy is due to the carburator. hopefully when i do the big upgrade i'll get 15 or higher.
projectdagger
Aug 6, 2007 09:16 PM
lesoster
Apr 25, 2007 11:50 AM
mudadiction
Feb 28, 2006 12:37 PM
mike_2000
22
Nov 9, 2003 11:04 AM
aunchman
Sep 24, 2003 08:00 PM
