1997 460 Performance Mods. Need Help?
Old Apr 23, 2007 | 07:10 AM
lesoster's Avatar
lesoster
I own a 1997 F250 4x4 with a 460 engine. I use this truck as a tow vehical. The original motor is really underpowered and I am considering replacing the original engine with a new 550HP 460 crate motor from Ford Racing. My existing engine uses fuel injection (EFI) and the crate motor is carburated. Here are my questions.
Option 1 - Convert the crare motor to fuel injection (EFI)
a. Will my existing EFI manifold bolt directly to the new crate motors Super Cobra Jet heads?
b. If not, who makes an aftermarket EFI manifold for this crate motor?
c. Does my truck's on board computer require any mod's to run this set-up?
Option 2 - Install the "carburated" crate motor in the truck
a. Will this affect my on board computer?
b. What computer mod's are required to run a carburated motor in an EFI truck?
Any help from someone who's "been there" is greatly appreciated!
CLO
Old Apr 24, 2007 | 08:25 AM
krewat's Avatar
krewat
FTE Leadership Emeritus
Moved to the 385-series forum - I think you'll get more answers here instead of in the FE forum
Old Apr 24, 2007 | 11:12 AM
Troy Bredthauer's Avatar
Troy Bredthauer
with that engine youre going to have to go to a carb. change ignition, fuel pump, either delete the stock pumps or use a fuel pressure reg. with no more than 8 psi. i dont know what to say about engine balance, flywheel or flexplate. this engine comes already assembled i believe
Old Apr 24, 2007 | 12:16 PM
leadmic's Avatar
leadmic
Buy a stroker short block. Send your heads to Scott J to have them ported and larger valves installed. Port the intake, get larger injectors, and have the ECM reflashed. But if you live in Cali. I dont know how your going to get it smoged. Or go the way Troy said, but if you have a auto you will have to get a stand alone computer to make the tranny shift. If you have a stick no problem, but you still cant smog it.
Leadmic
Old Apr 25, 2007 | 07:39 AM
lesoster's Avatar
lesoster
460 Need Help
Can you send me the contact information for "Scot J" for head porting and also let me know how to get my ECM "reflashed", as I do have an auto trans.
Thanks
CLO
Old Apr 25, 2007 | 11:50 AM
leadmic's Avatar
leadmic
I dont know if they will let me post the link so if you dont see a link after this just do a search for the madporter on FTE thats his handle on this board. Heres the link maybe. www.reincarnation-automotive.com
He is the best I know of for porting the fulie heads.
As for the ECM reflash you need to contact a SCT dealer. Their is one that is a sponser of this board. Just go to the top of the page under shop and click parts and acess.
_Leadmic_________________
old farm truck
General Automotive Discussion
Jun 3, 2016 08:55 PM
saltbranch
May 24, 2016 09:38 PM
Sleekcraft76
Jun 4, 2015 10:15 PM
White Mountain Goat
Nov 7, 2014 12:19 PM
DILLIGAF13
Jul 10, 2011 09:23 AM
