Heater fan speed
My heater fan only runs at high speed. I just replaced the fan speed switch on the dash. The fan still only runs on the high speed. What else can I check out.
Thanks for any help.
R J F
R J F
Last edited by R J F; Aug 24, 2005 at 06:43 PM. Reason: forgot to insert year of truck 93 inline 6 auto no ac
Originally Posted by R J F
Scott thanks for the info. Is this located under the dash or under the hood? Also an idea what it looks like would help.
Thanks again,
Rich
R J F
Thanks again,
Rich
R J F
Text book resistor.
Look above the exhaust manifold, as close to the firewall as you can get... just as he said above.
EZ fix.
EZ fix.
Hi,
Had similar problem. My mechanic neighbor suggested checking the blower resistor - he was right. Had to find it - inside the passenger compartment ('99 F150 SuperCab), under and a bit in front of glove compartment, beside the blower motor.
Chunks of the resistor assembly were corroded. Bought replacement from Ford dealer (part no. 4L3Z-19A706-AA, under $25 Cdn).
Watched it in action, while connected to the wiring harness, outside the blower duct (?). Two of the resistors operate red hot when the blower was running on the first 2 low settings of the blower speed dial. Mounted it in its place. Seems to be working OK. But, have a feeling it will need replacing in another 4-5 years from now.
Good luck on solving your problem.
Thanks to all who replyed. I found the blower resistor in my 93 it was under the hood in the heater duct work next to the heater fan. I took it apart and I'm waiting for a part to arrive from ford. Thanks again all.
