My Pioneer door speaker on the passenger side hits and rattles against the door panel everytime Bass or any other loud sound comes through. It doesn't do it on the driver side. I tried putting a spounge infront of the speaker but it sounded like crap and really muffled. Any suggestions? It makes the rest of my "Poor man installed system" (Politicaly correct as I can put it.) sound terrible.
Thanks.
I had the same problem. I put little rubber washers between the speaker and the door at each screw. The screws loosen under vibration and the result is this rattle. My buddy used silicone caulk to stop the loosening. He's happy with the results.
Also, you'll probably notice that the window cranks rattle quite a bit. That never bothered me enough to fix it yet.
