no more wheel weights?
Old Aug 24, 2005 | 09:09 AM
agoldberg03's Avatar
agoldberg03
Has anyone heard much about these things? I was just checking out www.innovativebalancing.com I don't quite understand how a million little beads in your wheels will balance your tires. Won't they all just go to the heaviest spot?
Old Aug 24, 2005 | 10:13 AM
dwildmanj's Avatar
dwildmanj
I went to the sight you indicated, and I, too, would like to find out more. They don't seem to give a thorough enough explanation. I understand the principal of centrifugal force and that it would probably distribute the little 'beads' inside the tire, but they don't go into enough details.
Old Aug 24, 2005 | 11:49 AM
JD717's Avatar
JD717
I dont buy it, theres no way a ton of little beads are gonna know how to balance a tire out. I prefer time tested and PROVEN technology, even if it is ancient.
Old Aug 24, 2005 | 02:30 PM
fordboy_52's Avatar
fordboy_52
how much do u ppl wanna bet? this what what we have been doing in semis for years... they throw in a bag and it balances out the tire... they do work
Matt
Old Aug 24, 2005 | 03:24 PM
gopher18's Avatar
gopher18
Agreed!
Old Aug 24, 2005 | 11:04 PM
nightme_02's Avatar
nightme_02
I second it
Old Aug 25, 2005 | 03:23 PM
guessrow's Avatar
guessrow
How much $$? Where to get?
my tires need major help! They are way out of balance, well kinda out. How much does it cost for 4 tires? Where can i find them?
TIA, jim
Old Aug 25, 2005 | 05:44 PM
agoldberg03
Follow the link on the first post. After you do it, let us know if it works. I still think that it would be counter-effective. Centrifigal force seems to tell me that heavy object will move to the outside of a circle. I'd love to hear some feedback.
Old Aug 25, 2005 | 08:25 PM
guessrow's Avatar
guessrow
I just ordered some...
Well, I cost a little over $30, but my curiousity was peaked enough to try it. I'll let you all know when I get it in and drive it a bit..
Jim
Old Sep 20, 2005 | 03:11 PM
Dave257's Avatar
Dave257
This works!
Long story, but new tires balanced three times and still not right, after a quick 10,000 miles I saw this post and gave them a try. Runs as smooth as a ribbon now.
Dave
Old Sep 21, 2005 | 09:27 AM
matis's Avatar
matis
Must I go to the tire shop?
Or can I simply pry off the wheel weights and pour these in through the valve stem?
matis
Old Sep 21, 2005 | 10:54 AM
Dave257's Avatar
Dave257
You can put them in the valve stem, takes a few mins , be paitent. You need to order their install kit and the valve cores. I left my weights on for a test run and all is well, they do recommend you take them off, I will when I get time. Only complaint I have is their shipping is a little high, If you want quick delivery.
Dave
Old Sep 21, 2005 | 04:53 PM
matis's Avatar
matis
Thanks for the reply Dave 257. That's what I was hoping to hear.
Here's another question, if you would: My tires are near the end of their lives. Are these things re-usable?
They sound like a better way to balance tires, either way, but if they are re-usable then I don't have to wait to buy them.
thanks, again.
matis
Old Sep 21, 2005 | 04:59 PM
Dave257's Avatar
Dave257
Once they start rolling around inside the tire, I don't see how you could gather them up to put into another tire. If you buy new tires they can put them in when they are mounted. Thats the way I would go. I only have about a 100 miles on them, so I don't know how they will hold up, but will add posts if I run into any problems.
Dave
On edit: Had a place to run it up to 85, smooth as silk.
Old Sep 22, 2005 | 09:50 AM
matis's Avatar
matis
Could they not be taken out as the old tire is removed from the rim?
It'd be great to get this installed now and not have to wait for the new tires.
Either way, this sounds great!
Thanks,
matis
