I'd start with plug wires, especially if you are at 60,000 or higher and have never changed them.
Start with the basics first. Plug and wires are known to cause the problem you mentioned.
I have no experience with the Split Fire plugs so I can't say if they work well in the 4.2.
I have had good luck with Motorcraft OEM plugs and Autolite or Champion copper core plugs.
I don't think it is the o2 sensor because I haven't seen the check engine light on yet.
The SplitFire plugs aren't bad and my 4.2 seems to like them fine. But it runs real rough every once in a while. If it does it again, I'll have to take them out and put Motorcraft back in it. I just wanted to experiment with SplitFire and see how the 4.2 liked 'em.
What color should I look for on the plugs when I take them out? If I recall right, it was light tan? White would mean it is running too lean and black means it's running too rich. Is that right?
Thanks for helpin' out. Now I know what I have to do. If it wasn't for you guys, I would be having fits and get ripped off by the dealer.
First of all,ide yank them POS S***Fires and throw 'em away! Go back with factory Motorcraft plugs.Next,install some good plug wires.I dislike factory Motorcraft due to too much resistance in the wires. I am currently using Autolite Pro Series wires.Then,give the TB a good cleaning using a TB cleaner only! Clean your MAF sensor too.Finish off the job by cleaning the IAC.Remember to disconnect the negative battery lead before doing any work!
BTW,the O2 sensors will not throw a code until they "totally" fail.They do get "lazy" and will not be as effective with that many miles you have stated,on them.Another part to replace is the PCV valve.
BlueOvalFitter, why do Motorcraft wires have too much resistance in 'em?
Where is the MAF sensor at, so I can locate it and clean it out? The IAC is at the back of the intake manifold, I think. The PCV valve is on the passenger side of the valve cover. I know because I found it there.
I'll probably have to get new o2 sensors before the old ones fail.
I'll probably get started on the truck this weekend.
To find the MAF, look into the intake plenum after removing the air filter. It's located just after the air filter.
The MAF sensor assembly has a plug with 5 wires (I think it's 5) hooked to it.
The MAF sensor itsself, is a wire held in a little snorkle that sticks out into the air intake stream.
That wire is what gets cleaned. Break the wire and truck, she no go-go.
i didn't even know mine was bad. i was installing new headers and couldn't get my pass. side o2 out of the stock manifold, so i bought a new one. i didn't even realize how much smoother it was for about 2 days...ha!
i was sitting there at idle and said...."hmmm....ohhhh yeeeahhhh...."
