engine miss HELP
Old Aug 8, 2005 | 10:06 PM
kens crewcab's Avatar
kens crewcab
Unhappy engine miss HELP
i have a 96 crew cab 4x4 it has a engine miss when your on the trottle not real bad at idle, no codes so i think the wiring is ok [ inj harness ] how cane i tell what cly is missing can't pull spark plug wires
Old Aug 8, 2005 | 10:13 PM
DaBigTow's Avatar
DaBigTow
When I had similar problems on my '96, no codes were thrown, but the stealership ran a load contribution test (checks how each injector works), they came back with "an open or intermittent circuit on #8 injector". I replaced the internal wiring harnesses on the drivers side & the problem went away. When I replaced the glow plugs several months later, I replaced the harnesses on the passenger's side. Never misfired again.
You can disconnect the plug at the top of the valve cover to determine which side is misfiring, but that's as close as you can get without pulling the valve covers. Beware that the injectors run on 110vdc; that can give you one heck of a jolt.
Old Aug 8, 2005 | 10:21 PM
kens crewcab
thank you i had a code a few weeks ago the said open circit[ its late] cyl 5 and 7 which is the same harness
Old Aug 8, 2005 | 10:24 PM
barebackjake's Avatar
barebackjake
with that code im going for that harness
Old Aug 8, 2005 | 11:45 PM
DaBigTow's Avatar
DaBigTow
Change 'em all. It'll save you a bunch of grief down the road.
Old Aug 9, 2005 | 10:07 PM
kens crewcab
well i change the harness today it don't help, does anyone think it could be the idm, going to get one tomorrow to try ,next will be injecters
hush210
Supercharger, Turbocharger, Nitrous Oxide & Water/Methanol Injection
30
Oct 22, 2018 01:55 PM
2005 Ford
6.4L Power Stroke Diesel
Jun 9, 2007 08:28 PM
flyMike
Jun 21, 2005 07:18 AM
kutze2
New Member Introductions
Aug 31, 2004 11:02 PM
Sniperdude23
Mar 7, 2004 08:14 AM
