Gear Ratio
Old Aug 23, 2005 | 07:40 PM
hotrod48's Avatar
hotrod48
Question Gear Ratio
I have found the gear ratio of the rear end in my truck before in a previous post. But my speedometer is off and I would like to know the original gear ratio (The rear-end was swapped by the previous owner). My truck is a 1981 2wd F-100. So my question is what is the axle code 01.
Thanks for the help,
hotrod48
Old Aug 23, 2005 | 11:35 PM
fordborn's Avatar
fordborn
Thread moved to " Clutch,Transmission, Differential, Axle and Transfer Case" Lets see if you can get more responses to your question here.
I can't find a code 01 in my book.
Old Aug 24, 2005 | 08:52 AM
hotrod48's Avatar
hotrod48
Thanks fordborn. I couldn't find it either, but I'm sure someone knows.
Thanks,
hotrod48
Old Aug 24, 2005 | 10:28 PM
Purple55's Avatar
Purple55
Here's the link....
https://www.ford-trucks.com/forums/s...d.php?t=297637
Old Aug 25, 2005 | 09:33 AM
hotrod48's Avatar
hotrod48
Thank you so much Purple55. Now that is the gear ratio in the truck now (At least what the axle tag says). Would a 235/75/15 make the speedometer 10 mph slow compared to a 215/75/15.
Thanks,
hotrod48
Old Aug 26, 2005 | 10:14 AM
subford's Avatar
subford
A 1981 code 01 is 2.75:1 2800 Ford rear end.
joeplouff
Feb 9, 2016 09:19 PM
ocala562
1997 - 2003 F150
Jan 11, 2011 05:03 PM
67buckeyeF100
Aug 27, 2006 10:11 AM
79f150custom
Aug 4, 2003 09:58 PM
