Rear End Gear Ratio
Jan 10, 2011 | 04:30 PM
Rear End Gear Ratio
How do I find what the rear end gear ratio is in my truck? Is there a code located somewhere?
Jan 10, 2011 | 05:01 PM
Should be a metal tag on the rear. Or you can get it off the door sticker. If the rear is still stock ,one or both of them will tell you.
Post the number and someone will decipher it for ya.
Jan 11, 2011 | 07:02 AM
Axle Decoder Chart
Code Ratio Capacity Maker Type
12 2.73 3800 FORD REG
17 3.25 3300 FORD REG
17 3.31 3800 FORD REG
18 3.08 3800 FORD REG
19 3.55 3800 FORD REG
25 4.10. 5300 FORD REG
29 3.55 5300 FORD REG
35 4.10. 6250 FORD REG
36 3.73 7400 DANA REG
39 3.55 6250 FORD REG
45 4.10. 7400 FORD REG
49 3.55 7400 FORD REG
65 4.10. 8250 FORD REG
69 3.55 8250 FORD REG
72 4.63 11000 DANA REG
73 5.13 11000 DANA REG
H5 4.10. 3800 FORD LIMITED SLIP
H7 3.31 3800 FORD LIMITED SLIP
H8 3.08 3800 FORD LIMITED SLIP
H9 3.55 3800 FORD LIMITED SLIP
B5 4.10. 5300 FORD LIMITED SLIP
B9 3.55 5300 FORD LIMITED SLIP
C5 4.10. 6250 FORD LIMITED SLIP
C9 3.55 6250 FORD LIMITED SLIP
D5 4.10. 7400 FORD LIMITED SLIP
F5 4.10. 8250 FORD LIMITED SLIP
W5 4.10 8250 FORD LIMITED SLIP
here you go, all ford's axle codes
Jan 11, 2011 | 09:02 AM
highteckredneck -Thank's for the info
Jan 11, 2011 | 05:03 PM
You have to make certain you use the correct chart for the specific year and model vehicle in question (which wasn't provided)....
For example, here's the chart for an 03 F150:
Quote:
18 — 3.08, non-limited slip
19 — 3.55, non-limited slip
24 — 3.54, limited slip
26 — 3.73, non-limited slip
27 — 3.31, non-limited slip
B5 — 4.10, limited slip
B6 — 3.73, limited slip
H9 — 3.55, limited slip
As you can see, the above posted chart isn't complete.
Green72F250
Jul 8, 2014 03:34 AM
homertwo
May 25, 2012 09:25 AM
emophreak28
Apr 5, 2011 05:43 PM
calazo
Jun 2, 2004 08:17 PM
sshannon74074
Jan 1, 2004 01:34 PM
1973 ,
1997 ,
2007 ,
42 ,
99 ,
end ,
expedition ,
f150 ,
ford ,
gear ,
gearing ,
gears ,
ranchero ,
ratio ,
rear ,
stock ,
superduty
