Need Help Figuring out Gear ratio
Old Feb 9, 2016 | 12:15 PM
joeplouff's Avatar
joeplouff
I have a 1955 f350 with 5.83 ratio, the motor is the 223 inline 6. With this ratio it will only go about 40 to 45 mph max! My plan is to hotrod this motor, and by hotrod I mean different manifold so I can attach 3 carbs, alternator and such. More HP less MPG, would it be smarter to stay with this ratio so it can handle the more HP or should I swap out the gears or maybe even a whole rear end swap? This is my first truck that I want to rebuild and make a sweet ride out of, so I'm pretty new to all of this. I have found a couple ratios that were lower but not sure what to do since I am going to be upping the HP. I kind of babbled on in this thread I hope I made sense.
Pictures posted are from when I bought it.
Old Feb 9, 2016 | 04:40 PM
jniolon's Avatar
jniolon
old and in the way
Joe... quick and dirty... jack up the rear end... wheel chocks under front tires. mark the tires with a reference line... mark the rear u-joint. Either by yourself or with a friends help... one turns the wheel and counts the turns... the other watches for the number of turns on the driveshaft... 3 turns to 1 turn = 3.0 to 1 ... lots of places on the internet with this info
later
john
Old Feb 9, 2016 | 05:14 PM
truckeemtnfords's Avatar
truckeemtnfords
Veteran: Marine Corps
To be the most accurate you should spin BOTH rear tires together so that the spider gears do not mess with your calculations.
Old Feb 9, 2016 | 05:58 PM
ALBUQ F-1's Avatar
ALBUQ F-1
I think his question is what options does he have for a lower ratio?
First thing is, does the truck still have split rims, that would have been stock on that truck? If you post close-up pictures of the outer rear rims we can identify them for you. You can also search on "RH-5 Firestone rims" or "widowmaker rims".
The easiest way to get rid of them, and get safer rims, while getting a lower gear ratio, is to swap the rear end out for a more modern F350 axle, up to '72.
Old Feb 9, 2016 | 09:19 PM
38 coupe's Avatar
38 coupe
Please be aware that typical hot rod upgrades like bigger cam and more carburetors do nothing for power at low r.p.m. The 223 is a great engine, but it is small. Depending on how you plan to use your truck you could put a lot of effort into upgrades that do not work well together. For getter advice please tell us:
Do you plan to haul heavy stuff on the flatbed?
Do you plan to tow stuff heavier than small jet skies?
Do you plan on driving the truck daily?
Will you be going up and down hills much when you drive your truck?
How satisfied will you be with a 50 m.p.h. truck? A 55 m.p.h. truck? a 60 m.p.h. truck?
And Ross brings up what should be your first concern, safe wheels. Please make sure you have safe wheels before doing any other real work on the truck.
Welcome to FTE, thanks for starting with pictures.
weekendfarmer
13
Aug 31, 2018 02:55 PM
bigfoot17
Sep 4, 2012 09:11 PM
JRCF
Apr 14, 2008 05:58 PM
Jacksfirstdiesel
Jan 15, 2007 10:55 PM
dunbar15
Jun 1, 2005 12:20 PM
