i just bought some new fog lights and really dont know how to wire them in. i mounted them and thats it . i dont know where to begin give me some guideness please.
it did come with a harness.it has a switch, red white and 2 black wires.
i have the lights all hooked up i got that far.and have th switched all hooked up but dont know how to hook it up to get power.??????????
How do you want them to come on? If you don't want to run wires through your firewall, which is very easy, then get a relay and tap into your low beams.
Here's your wires.
1 - Wire coming off the low beams to activate the relay. Just use a blue 2 wire crimp for this.
2 - Ground wire from relay to wherever. Just find a sheet metal screw near by.
3 - Power wire from battery to relay. This one is the actual power supply. Use a 12 or 10 gauge wire depending on the wattage that you are gonna run in the lights.
4 - Power wire to the lights. 12 or 10 gauge again.
5 - Ground wire coming off the lights. Hook it in anywhere convienient.
