valve guides!
Old Aug 23, 2005 | 12:08 PM
Six Niner's Avatar
Six Niner
Cool valve guides!
well ive been burning oil for awhile now and finally leaked the motor down. it doesnt look like rings thank heavens. but i do have oil leakage around ALL the spark plug threads which leads me to believe i may have to put valve guides in it. sounds like fun to me, what do you guys think? sheesh
Old Aug 23, 2005 | 03:12 PM
bertha66's Avatar
bertha66
My 65 F-100 was doing something like that, pulled the valve covers and all the seals were gone, not realy gone, fond them in the oil pan. My son and I replaced the seals using the rope in the clyinder trick.
Old Aug 23, 2005 | 03:15 PM
ford390gashog's Avatar
ford390gashog
i would pull the valve covers and see. it could be the seals
Old Aug 23, 2005 | 04:02 PM
rusty70f100's Avatar
rusty70f100
Yep, I'm going through the same pain and agony on my 390. I pulled the heads, oiley goo on top of all the valves, chambers full of goo. Went through a quart every 250 miles. So I took the heads up to the machine shop, and had ALL new guides put in, and I'm going to be using ALL new valves. Really, this is the only way to fly on any engine build IMO.
"It's good enough" doesn't cut it.
Old Aug 23, 2005 | 04:48 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Pull the valve covers and make sure the head drains are flowing freely!
Even with good guides and valve seals, too much oil up in the valve cover will burn oil like you own a diesel
Old Aug 24, 2005 | 12:41 AM
discman's Avatar
discman
edelbrock heads will cure that problem
Old Aug 24, 2005 | 02:54 AM
ford390gashog
they will also make your wallet lighter 1,500.00
Old Aug 24, 2005 | 04:55 AM
RapidRuss's Avatar
RapidRuss
FE "Freakin Expensive"
Knurling Guides is just a joke!! If you ever cut a guide in half thats been knurld it would shock you how little contact and seal the valve actually has!! JMHO!!
Russ
Old Aug 24, 2005 | 07:59 AM
Six Niner's Avatar
Six Niner
thanks for the input guys, i was going to pull the valve covers last night but didnt get to it. i do know the guides were knurled. im going to check the seals as well. the seals on my fairlane were all pulled loose and caused a lot of smoke. thanks again.
Old Aug 24, 2005 | 08:34 AM
rusty70f100
Knurling CAN be done right, but most shops dont. The right way to do it, is to go ahead and knurl 'em, then press a pin through 'em to squish it back out to the proper dimension. The improper way to do it, is to knurl it and drill it out to the proper dimension. This doesn't leave nearly enough material.
Old Aug 24, 2005 | 10:21 AM
1975Ford's Avatar
1975Ford
If you do take the heads to the machine shop, have them put steel seats, you then can burn unleaded gasoline.
Old Aug 24, 2005 | 12:41 PM
Six Niner's Avatar
Six Niner
yeah its got seats put in it already. i should have just went ahead and put bronze guides in from the get go. oh well live and learn.
Old Aug 26, 2005 | 03:23 PM
Six Niner's Avatar
Six Niner
well i pulled valve covers and found that the valve springs have pulled the umbrella seals off. may have to go to a pc seal or something. thanks for the input guys.
Old Aug 26, 2005 | 03:52 PM
krewat's Avatar
krewat
Do you have double springs? Or a high-lift cam?
Either one of those kinda necessitates the smaller push-on seals... but then, you need to go to bronze guides too, because then the valve stems get NO oil...
Old Aug 27, 2005 | 12:28 AM
highboy 74's Avatar
highboy 74
My seals did exactly the same thing. I tried finding some high heat seals and had very little luck with the stock valve guide size of .648. I called summit and the guy found me some teflon seals that will work with the stock guides. The part number is CCA 512-16 he told me that they would have to order them and that he did not know what the price was because it is not something they stock. Hopefully these seals will last longer than my other ones did. I have the dual spring setup with the bronze guides.
JCount
Dec 8, 2016 10:21 AM
dustinlauricha
Mar 4, 2012 12:48 AM
PagodaMomar
Nov 16, 2010 04:26 PM
paulietools
Jul 7, 2009 12:58 AM
DarylZ
Oct 22, 2004 03:20 PM
