Am I being snowed??
Old Jul 6, 2009 | 11:01 AM
paulietools's Avatar
paulietools
Am I being snowed??
I called a local garage with a good rep and asked them if they could do a leakdown test on my truck to help me determine if it was the valve guides or the rings that are the cause of my oil consumption.
The response I got was "All a leakdown test will tell you is if the bearings are any good. There isn't anyway to tell if it is the rings or the guides. Just do the heads and if it doesn't change then it is the rings".
Seems like a bunch of BS from everything I have read here.
Old Jul 6, 2009 | 02:00 PM
Conanski's Avatar
Conanski
So much for that place having a reputation the person you talked to hasn't a clue.. but then service managers seldom do.
Old Jul 6, 2009 | 03:30 PM
Freaksh0w's Avatar
Freaksh0w
Yeah, I was going to say maybe to call them back tomorrow and hopefully you will talk to someone with just a tad more sense. Whoever you talked to has a good idea if money grew on trees.
Old Jul 6, 2009 | 08:07 PM
dinosaurfan's Avatar
dinosaurfan
Smile try again
Paul, either try the same shop but ask to speak to someone else, or go to another shop. Obviously the person you spoke to doesn't know what type of test you are talking about. DinosaurFan
Old Jul 6, 2009 | 09:51 PM
393STROKER's Avatar
393STROKER
How do you go about checking the valve guides w/ a leak down test ?
Old Jul 7, 2009 | 12:58 AM
Beanscoot's Avatar
Beanscoot
The shop must have been thinking about an oil leakdown test, which does of course check for excessive bearing clearance.
A cylinder (compressed air) leakdown test will test the valve seats and rings.
393 Stroker has a good point.
grandpawj
Nov 12, 2012 10:10 AM
briguy
18
Mar 15, 2007 09:41 PM
natron037
1997 - 2003 F150
Apr 5, 2006 09:50 PM
Roushians
Mar 9, 2006 10:05 PM
jqp00002
Jan 29, 2006 10:41 PM
