1978 - 1996 Big Bronco
transmission cooling lines
Old Sep 9, 2008 | 07:11 AM
jomo924's Avatar
jomo924
my tranny lines got mangled during an engine swap out,,, can i cut the damage out and splice lines with quality tubing?? can i make new lines from aero-quip hose??? how much pressure is in any of these lines ever maximum????????
Old Sep 9, 2008 | 07:54 AM
sowder's Avatar
sowder
On my 79 I used 5/16 brake line, worked great.
Old Sep 9, 2008 | 01:35 PM
jomo924's Avatar
jomo924
too many bends to use brake line
Old Sep 9, 2008 | 10:47 PM
Bluebronco85's Avatar
Bluebronco85
Ck. You can connect lines using tubing/hose or get a compression fitting the right size for your tranny lines. I have successfully connected line both ways. Jus keep in mind you need a tight fit due to tranny fluid being so thin and finds places to leak easily.
Old Sep 10, 2008 | 06:41 AM
sowder's Avatar
sowder
The only sharp bends are at the trans. you can buy a cheap bending tool for $10, it may be harder to do but you won't have problems later.
87thhunter
Jun 16, 2014 03:02 PM
bstarz40
Nov 23, 2012 05:35 PM
tygarcia
Apr 20, 2004 10:16 AM
volks
Dec 19, 2003 06:08 AM
