Master Cylinder?
Old Aug 22, 2005 | 09:41 AM
cdorroh's Avatar
cdorroh
Master Cylinder?
'68 F250 4x4 with '73 d60 axles and drums all around.
My master cylinder is shot, but which spec should I use to replace it.
Seems that since the axles (and brake drums & wheel cylinders) are from a '73, that I should replace the master cylinder with a '73 spec?
Any thoughts?
Thanks.
-Craig
Old Aug 22, 2005 | 10:47 AM
Mike G's Avatar
Mike G
You will probably find that the part number associated with a MC for a 68 4X4 and a 73 4X4 are the same... Just make sure you get one for a drum/drum setup.
--Mike
Old Aug 22, 2005 | 06:56 PM
cdorroh's Avatar
cdorroh
Similar part numbers, yes...but not exact. According to Napa, the same MC was used on the '68 w/o power brakes and the '73 w/ power brakes. I have been running a booster, so that problem is solved.
Strange that the fluid leak is at the MC - either coming out from the cap or from the bolt on the bottom - both line connectors are "dry".
It's on the back burner for now, anyway - my clutched dropped out this afternoon. I've had a bad rear main seal leak for a while, which caused the clutch to chatter and wear. I knew it was only a matter of time.
Thanks for the help.
-Craig
Old Aug 23, 2005 | 09:18 AM
Mike G's Avatar
Mike G
-Craig
I have actually had the cap leak before, took it back and got a replacement...
--Mike
Old Aug 23, 2005 | 10:36 PM
rebocardo's Avatar
rebocardo
My cap leaks too and I noticed the cap boots do not go into the fluid like they are suppose to and take up the empty space when the fluid level drops.
One from a 1971 F-350 with DISC brakes will work swell. I got mine with disc (even though I have drums all around) because I wanted extra braking to the front drums so the truck stopped better and straighter without locking the rear brakes as much. The booster/mstr cyl setup for the F-350 was much bigger then the F-100 (F-250?) stock size.
Old Aug 23, 2005 | 10:39 PM
Ford_Six's Avatar
Ford_Six
I thought that the 1ton+ trucks had a different pedal assembly?
Old Aug 24, 2005 | 12:41 PM
cdorroh's Avatar
cdorroh
Don't know if the 1-ton trucks have different pedal assemblies - isn't the F250 a 3/4-ton?
-Craig
lynn s 460
Nov 24, 2013 04:43 PM
Macs1964F100
Nov 20, 2013 10:44 PM
664x4drvr
Nov 24, 2012 10:34 AM
crazed87bronco
Sep 28, 2010 06:42 AM
64STYLE
Jul 12, 2007 06:30 PM
