1979 F150 engine stuck
Old Sep 5, 2002 | 07:06 PM
burny1's Avatar
burny1
Just installed a re-built 351M/400 engine. When you turn the key the engine will spin about 2 inches, however it turns easily with a pipe wrench. I have replaced the starter as well. Any other suggestions?
Thanks
Old Sep 5, 2002 | 08:18 PM
theonlybull's Avatar
theonlybull
take the plugs out, and see if the starter will roll it over... if not , then there's something serious wrong..
Old Sep 5, 2002 | 09:07 PM
bigf150's Avatar
bigf150
Is the battery dead?
Old Sep 5, 2002 | 09:11 PM
Mike W's Avatar
Mike W
If the battery and cables are good, It is probably a bad starter. When you get it started, keep the rpm's above 1500 for 20 or 30 minutes to break in the cam and lifters. Drive it, it may tend to run hot for a few miles and then the temp will drop. Have seen this happen several times.
Old Sep 12, 2002 | 09:03 PM
burny1's Avatar
burny1
Battery and cables are good. Removed plugs and it rolls over smoothly. Put plugs back in and it slows it down by 2/3. What about a hi torque starter? Think that would help. Seems to have very high compression.
Old Sep 12, 2002 | 09:07 PM
bigf150's Avatar
bigf150
[updated:LAST EDITED ON 12-Sep-02 AT 10:07 PM (EST)]somtimes with new enginges its hard for them to turn over the first time cause nothing is broken in and everything is really tight. try putting a booster on the battery also. Did you prime the engine also?
Old Sep 12, 2002 | 09:09 PM
burny1's Avatar
burny1
Have put booster on the battery. Not sure what you mean by prime the engine. Could you explain please. Thanks
Old Sep 12, 2002 | 09:12 PM
burny1's Avatar
burny1
>prime the engine. Could you explain please. Thanks Also, it seems to get looser each time I try to turn it over. Could it be that just playing with it for awhile would get it to cut loose?
Old Sep 12, 2002 | 09:15 PM
bigf150's Avatar
bigf150
well somtimes you take the drive gear off of an old distributor and use the hex end of it on a drill to put on the oil pump rod to run the oil pump to give the engine oil pressure before you start it.
Old Sep 12, 2002 | 09:22 PM
hillbillyk's Avatar
hillbillyk
check the timing, make sure the distributor is not too far advanced, I know this makes them turn over slow hot, might also do it when it is cold, not sure, someone else might know better.
Old Sep 12, 2002 | 09:23 PM
otto's Avatar
otto
I wouldnt drive that one far
burny1's Avatar
burny1
I will give that a try. Haven't done that yet. Thanks for the info.
Old Sep 12, 2002 | 10:11 PM
Mike W's Avatar
Mike W
If the starter is a re-built one that you got for the new engine, I would replace it with a known good starter.
Old Sep 16, 2002 | 10:42 AM
Doorgunner808's Avatar
Doorgunner808
Old Sep 18, 2002 | 07:42 PM
burny1's Avatar
burny1
Got the truck to finally start. Runs like a champ. Thanks for all the help.
tbarclay
Jan 13, 2014 03:01 PM
msriverrat
May 14, 2013 08:02 AM
durst2020
Nov 1, 2011 11:15 AM
fire105
1997 - 2003 F150
Jan 12, 2006 11:56 AM
jeby
Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150
Feb 7, 2005 11:48 AM
