HELP PLEASE!!! turn signals only work sometimes
Old Jul 29, 2011 | 08:46 PM
durst2020's Avatar
durst2020
So when i turn the key to the on positions and turn on the turn signals they work. Then when i turn on the engine and turn on the turn signals they do not work. I replaced the turn signal flasher and the fuse and i still have the same problem. What could it be?
Old Jul 29, 2011 | 08:55 PM
Seabiscuit-P3's Avatar
Seabiscuit-P3
Veteran: Navy
Veteran: National Guard
Give us the vital statistics on your rig, i.e., year, model, engine, towing package or not..........etc., etc.
Old Jul 29, 2011 | 09:04 PM
Superred2's Avatar
Superred2
Once you crank your truck, turn one of your signals on and then slightly turn the key forward and backward and in and out without turning the truck off. If the signals begin to work, it may be the switch.
Old Jul 29, 2011 | 09:07 PM
cj06's Avatar
cj06
look for any bad connections in your fuse box or any place else , grounds also !
Old Jul 29, 2011 | 09:26 PM
durst2020's Avatar
durst2020
it is 84 f-150, 4.9l v6, no towing package
Old Jul 29, 2011 | 09:38 PM
Franklin2's Avatar
Franklin2
I agree, wiggle the switch. I bet your wipers and some other stuff are acting flaky also.
Old Jul 30, 2011 | 02:19 PM
spongecop's Avatar
spongecop
Semper Fi
kind of stupid but i had similar problems with mune after a new signal and ignition switch. turns out the hazard switch was pulled half way out thus interferring with normal signal operation
Old Nov 1, 2011 | 11:15 AM
jeep-rally's Avatar
jeep-rally
Same issue
I had same issue. It was in fact the ignition switch. I replaced it and I guess there was some crud and it would not completely reset itself from the start back to the run position, you had to do it manually. After a little while of driving and rocking back and forth it resets normally every time now.
f350hammer
Feb 9, 2014 08:08 AM
earl964
Jun 25, 2006 07:00 PM
biggut
Jan 25, 2006 10:16 PM
1988XLT2002
1978 - 1996 Big Bronco
Nov 13, 2002 06:22 PM
