Max AC Problem
Old Aug 22, 2005 | 07:04 AM
ChexBoss's Avatar
ChexBoss
Exclamation Max AC Problem
Hello. I'm new to FTE.
My dad and I recently bought a used 1995 Ford F150 for me to drive. I love it. But there is one problem.
The Max AC Fan makes a weird noise when it's running. The noise is coming from underneith the passenger side dashboard. But the noise does not occur if the ignition is in the "On" position, the engine has to be running. The noise almost sounds like a leaf is caught in the fan chamber. 1) I don't know how to access that chamber, 2) I'm not even sure if that is an issue.
Incase any more information is critical to what is causeing the problem, here are my truck stats.
1995 Ford F150 XLT
Regular cab
8' Bed
5.0L V8
Automatic Transmission
Working AC/Heat
Power Locks/Windows
Custom JCV CD AM/FM Radio.
Old Aug 22, 2005 | 09:52 PM
Fully_Loaded's Avatar
Fully_Loaded
the fan motor and fan cage come out with three bolts under the hood. When you pop your hood look in the far passenger corner up against the firewall you will see a round thing about 10'' in diameter that is your fan. Take those 3 (maybe 4) bolts out and the motor and fan cage will pull out just remeber to seal it back up when you reinstall it.
Old Aug 27, 2005 | 10:51 AM
ChexBoss's Avatar
ChexBoss
Thanks. Problem solved.
I opened it up, and sure enough, I found 2 plastic sacks from AAFES inside. One of which was shredded.
Thanks. I shall now have a quiet ride.
Old Sep 4, 2005 | 09:27 PM
Fully_Loaded
Great glas that we could help
Guhfluh
Sep 21, 2013 02:58 PM
kaduh
May 22, 2011 11:32 AM
gottadog
New Member Introductions
Mar 10, 2009 07:11 PM
ptt
Dec 28, 2008 04:44 PM
PCWest13
Aug 23, 2006 10:21 PM
