In my search for a top shift 3 speed syncro trans to replace the crash box in my 51 I came across a side shift 3 speed that is next to perfect inside. It was locked up and i suspected the shift forks might be out-of-sink. Turns out it was the shift forks, I noticed while cleaning it, there was no speedometer hookup. I realized it nust be a torque tube unit.
My Question, if I can find a truck 3 speed floor shift case can I transfer all the international components from this case, into that case.
When you say that your current trans is a crash box, do you mean a heavy duty three speed? They are unique. The side loaders of that era were car or light truck transmissions.
No it's one of those 4 Speed spur gear Non-syncro (crash box) units. My 51 is an F1, I have an S-10 4X4 5 speed trans to put in it someday. When funds allow and I find a Mainshaft and Tailhousng to convert it to 2wd. I just want a syncro 3 speed for now, so I can install my 9" 3:24 rearend. I need to take it on a 600 mile road trip to pickup some parts. That 4 speed and the 4:27 gears in it now just don't cut it for my intended use.
Hi Chris, It's the down shifting 4th to 3rd that gives me trouble. If I slow down to about 10-15mph around a corner with the 4:27 gears it's not too bad. My thoughts are with the 3:24 the drive shaft will be spinning a lot faster. Thus making the double clutch down shift a real grinding experience. I could be wrong on that, but I just been thinking it would be best to install a syncro trans a the sametime as the rearend. My biggest headache at the moment is my F1 is now my daily driver, I can't have it sitting for a week at this time. It's a two edged sword, when they sit we think it needs to be driven. When driven they quickly become a dependent vehicle and we can't afford to have it down. Don't understand it but my 87 Accord literly started having constant one thing after another happen just days after the F-1 was on the road. I think it was just luck I got it on the road when I did.
If you switch to the 3:27 gears the drive shaft and everything will be spinning slower to do the same speed. Anyway, have you thought about a 4 speed out of a newer truck? I have a synchronized 4 speed out of a 1951 F600 that came with the the 254 flat 6 I bought. Did the 254 you bought have a transmission or is that the trip you need to make?
Thanks for correcting me, that rear might work ok with the driveshaft going slower, untill I can get the 5 speed installed. I would be intrested in your trans but the shipping alone to Seattle would probably cost a lot. Yes that's the trip I need to make, to pickup that engine.
Someone else should be able to help/verify the following. I was under the understanding that three different transmissions were available in F-1's (four techically if you count the both the light duty toploader and the side shifter-they contain the same gearsets). I ran my 49 initially with the light duty 3 speed floor shifter. After having to tear it down 2 or 3 times for repairs (I ran it behind a 56 Buick nailhead at the time), I found a heavy duty three speed which had spurcut gears with a syncro. There were no problems shifting that at all. Although it probably weighed 2 times the weight of the light duty 3 speed, it was a bolt in with the same length and output spline such that the driveshaft worked with either transmission. If the 4 speed is also a bolt in (I have not done this personnaly so I am not sure), then you can easily change to an open driveline (F-1) 3 speed floor shifter either light or heavy duty and get the sychro advantage. The key is the different output shaft/spine on the open driveline from the earlier torque tube type transmission. In my prime I could R&R a trans in the F-1 including a box teardown for damaged part replacement in under 3 hours. Good luck.
Yes shipping would be expensive, maybe the person who has the engine still has the transmission that was bolted to it also.
I ran a 52 Panel with 289, F1 4-speed crashbox, and Chrysler 2.73:1 rear for years. Double clutch downshifting becomes second nature. Highway cruising was effortless, 1st gear was plenty low enough (I usually started in 2nd). I first installed the rear with the three-on-the tree, and that was no fun, mostly 'cause the linkage was all worn out.
Don't hurt yourself getting that 4-speed up out of the truck - damn those things are heavy!
One quibble with the tranny list posted earlier - I'm under the impression that the three-on-the-tree was first availabe in 51. Ford advertised it as more room in the cab for your crew!
I believe the 3 on the tree first showed up mid-year 1950. Seems they did a lot of changing on the run that year (elimination of raised panels on F1 beds in 1950 also comes to mind).
Granted. Lots of changes mid-50. Does anyone know if the cab change was mid-50 or actually waited till they were called 51s? (off-topic, I know)
