9" questions
Old Aug 20, 2005 | 11:17 PM
Broke_Okie's Avatar
Broke_Okie
9" questions
I have a 71 F100 4x4 that has a 31 spline 9" rear dif with 3.50 gears and a factory limited slip. I want to install a 35 spline detroit locker and 35 spline axles. What will I need to do to carry this out? I have been told I need to modify the housing.Is this true?
Old Aug 21, 2005 | 01:24 PM
kennethl6's Avatar
kennethl6
I'm pretty sure you'll have to get a new aftermarket gear housing (hoghead) because the stock carrier bearings will not have a big enough hole for the axles to go through. I believe 33 spline axles are the largest that can be used with a stock gear housing.
Willz74
Nov 20, 2015 09:29 PM
overlandexpress
13
Jun 22, 2011 12:07 PM
bob_351
Mar 5, 2011 02:24 PM
larryejoh
1978 - 1996 Big Bronco
Jan 20, 2011 04:09 PM
notyettoday
Jan 16, 2009 04:42 AM
