56 Dash Insert ?
Old Aug 19, 2005 | 07:43 AM
learpilot's Avatar
learpilot
56 Dash Insert ?
I have recieved the dash insert (six guage) and I know the dash has to be cut to accept the guages. Since I don't yet have the guages but I need to cut out the dash now can anyone give some advice on how to do this? Do I cut out to follow the outline of the out side of the insert which means that I have about 3/ 16ths of overlap or do I cut out where the individual guages need to come through the dash? This question is probably as clear as mud but maybe you understand , thanks.
Old Aug 19, 2005 | 08:52 AM
fatfords's Avatar
fatfords
learpilot,
You might want to post a pic of your dash insert in a gallery so we can try to help you out. There are several different inserts available, but the ones I've seen that hold 6 gauges do require a kind of "half moon" arc to be cut out below the existing opening. Post a pic of yours and maybe we can help.
good luck,
Kent
Old Aug 19, 2005 | 10:27 AM
Fomoko1's Avatar
Fomoko1
You want to cut a 56 dash? Please be very carefull. I have done things in the past that were hard to undo and after I wished that I had not do so.
Old Aug 19, 2005 | 12:07 PM
B/B ford's Avatar
B/B ford
Clean & Classy
If your insert is like mine, a no limit 6 hole, you have to trim the bottom of the opening to follow curve of insert. There is not much room for error.
Old Aug 19, 2005 | 12:15 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Learpilot, I have been thinking about your question and I think your asking if you have to cut all the excess metal out? That is what we did on mine, and it left very little room for lower mounting holes. Im looking at my insert now with gauges in it and it looks like you would only have to trim enough to clear the actual gauge, leaving a little larger overlap.
I hope this helps Wayne
Old Aug 19, 2005 | 04:06 PM
learpilot's Avatar
learpilot
Thanks Wayne, that was my question, I plan to just cut enough to clear the guage holes leaving more metal behind the insert. Although the insert does not have a lower mounting hole, it would probably be best to secure it at the bottom as well. Can cast Al be drilled? Thanks again, Jerry
Old Aug 19, 2005 | 04:24 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Jerry, my insert has two threaded holes near bottom, 8/32. I'm mounting studs in them and then just running some nuts on from behind dash
Old Aug 19, 2005 | 04:30 PM
fatfenders56's Avatar
fatfenders56
Gee guys, just yesterday I ''made a decision'' and cut that speedometer hump out of the dash. Then I talked to the guys at Custom Components Machining about a new wall to wall billet dash, guess I did go over the edge (like that NEVER happened before)
Old Aug 19, 2005 | 06:10 PM
B/B ford's Avatar
B/B ford
Clean & Classy
Tim, it sounds like a great idea for your gauges! I'm looking forward to seeing some more pics of your truck.
Old Aug 19, 2005 | 06:34 PM
AXracer's Avatar
AXracer
Tim, I've left the hump with the black anodized new gauge plate but filled the glovebox and ashtray doors and had a brushed stainless panel made to cover the flat vertical section the length of the dash. I also had a sheet metal lower "skirt" panel made for the bottom that repeats the peaked shape of the top of the dash. The brushed SS panel will have no penetrations at all.
nstueve
29
May 21, 2017 06:28 PM
Fully_Loaded
Aug 8, 2009 07:05 PM
73Custom
Electrical Systems/Wiring
Nov 18, 2004 03:18 PM
mgundry
May 31, 2004 11:46 AM
rchassie
Feb 12, 2004 12:46 PM
