Door Rust~ Action Needed
Old Nov 28, 2005 | 10:55 AM
  #46
LoadedRound's Avatar
LoadedRound
Smile
Just wanted to say Thanks to all here. I dropped off my 2000 Expedition at the dealer this morning to have my rusty doors repaired at Ford's expense. Couldn't have done it without the knowledge you shared.
Thanks again
LR
Old Nov 28, 2005 | 11:02 AM
  #47
mcn420's Avatar
mcn420
Good Loaded Round. How did you do it!!?? I called the main 1-800 and they told me they couldn't do anything for me.
Old Nov 30, 2005 | 02:15 PM
  #48
LoadedRound
mcn420
Really wasn't too hard. They initially gave me a $1600 estimate saying it wasn't covered by warranty. I explained that I had internet access like everyone else and knew Ford had covered the repair for other customers. It took about 4 days of back and forth with the dealer. They came back and said Ford would take care of it. We never had any direct contact with Ford. Our truck was still under the 5 year corrosion warranty (don't know if that matters or not). The repair is supposed to be per the TSB.
Don't give up easily. Have you met with your dealers management? Start with the Service Manager and go up from there. You might try working through a different dealer? Have you requested a meeting with a zone rep? If you're enough trouble to enough people,(make everyone you meet with look at your truck, and I mean all four doors. Burn as much of their time as you reansonably can) I bet they will eventually take care of it.
Let me know if you further have questions.
Good Luck
LR
Old Nov 30, 2005 | 02:56 PM
  #49
D-town Dan's Avatar
D-town Dan
LR
Yes, it matters if the truck is under the corrosion warranty. I believe it is stated directly in the TSB. I'm glad you did not have much trouble getting your doors repaired.
Old Nov 30, 2005 | 09:37 PM
  #50
mcn420's Avatar
mcn420
Well, my truck is out of the 5 year warranty and I've already started treating and coating the rust myself. I should've raised more of a stink. Well again good work, and I hope others will do the same!
Old Nov 28, 2008 | 05:06 PM
  #51
scritley's Avatar
scritley
Originally Posted by ultimatenavi
After weeks of waiting we finally got a Ford Engineer to inspect our 2003 Navigator (48,000 miles) which has corrosion in all 4 door seams and the tailgate.
His first reaction was that it was not covered by the corrosion warranty and pointed out that we live in an area where salt was used in winter.
After pointing out that this was completely unacceptable on a $60,000 vehicle and much back and forth argument, he finally agreed as a courtesy to repair the damage. The next stage is for us to take it to the body shop that the Lincoln Dealer uses and schedule an appointment for the work to be done. They need the car for 2 days.
Next question is how thorough will be the repair and are there any guidlines for dooing this type of work
The TSB that I remember when I researched this 3-4 years ago (my 99 expy has same problem and it was out of warranty then) was that they would remove the door, open the seam, clean out any rust and corrosion, treat the seam with a seam-sealer/rust-inhibitor, and re-close the seam. It mentioned nothing about new seep holes being drilled, welding the seam, etc.
I know they are going to fix it for free (and that's great and I think they should), but see if they guarantee their work for any period of time. Whether or not they do, I would suggest babying the doors/seams afterwards. The body shop i took my Expy to said the fix would just be a band-aid... ie temporary. He could slow down the process, but due to the design, he could never stop it from rusting altogether.
Good luck!
Old Nov 29, 2008 | 10:56 AM
  #52
98expeditionXLT's Avatar
98expeditionXLT
I'm beginning to think that Ford should stop selling vehicles in areas where road salt is used. The amount of corrosion that is present on my 98 Exp is far worse than my 95 volvo with twice as many miles on it and the Expedition has been better maintained.
Old Nov 29, 2008 | 05:40 PM
  #53
Freak4Ford's Avatar
Freak4Ford
Well we all know that isn't going to happen. Hopefully they will continue to make quality Job 1 and come up with a better design in the future. Especially when you consider how Ford is bragging about how quality is on par with the imports now.
Old Nov 29, 2008 | 05:46 PM
  #54
alloro's Avatar
alloro
Here's the solution for stopping rust.
Allegheny Ludlum Stainless Steel
Old Dec 1, 2008 | 06:28 AM
  #55
98expeditionXLT
As an engineer who also does 90% of the maintenance on our four family cars, I feel Ford did a great job on the design and manufactuirng of the Expedition however Ford falls far short on the quality of the materials that are specified and on listening to the customer.
Old Dec 2, 2008 | 12:49 AM
  #56
The Real TLR's Avatar
The Real TLR
I'm in the process of repairing/replacing the lower horizontal rocker panels on my 97' with SS, since it has runing boards seems alot of crap got stuck up/in that area before I owned it and was not wshed out etc.
TLR
Old Dec 2, 2008 | 05:55 AM
  #57
mastiff's Avatar
mastiff
Hi
My 98 dosen't have any rust on the bottom of the doors. I live in New England and wash the truck once a week and wax everything on it twice a year.
Old Dec 30, 2008 | 10:07 AM
  #58
lees40's Avatar
lees40
Had the same problem on my 2000 Expedition. Took it to a body shop who fixed all 4 doors for me for $100.00, and told me to occasionally shoot some WD-40 liberally into the drain holes of the doors. I guess we'll see how this works out.
developer
2015 + Expedition & Navigator
22
Sep 18, 2018 08:46 AM
Locomotivepower
Oct 23, 2016 07:57 AM
Hurst89
2009 - 2014 F150
77
Apr 11, 2016 04:30 PM
RED DOG DADDY
13
Nov 4, 2008 05:11 PM
