Emergency brake cable hitting shift levers 52 f1
Emergency brake cable is hitting shift levers on 3 speed column shift 52 F1
Does anyone have any pictures of how cable is routed by bottom of steering column and shift levers. I see one clamp on bell housing that I believe should be mounted to clutch cover bolt.
Cable hits cotter pins on shift levers.
Any help appreciated
Tom
Tom
Ross
From underneath it looks like mine is attached where used to be attached. Tomorrow I will take off the access cover and check it out.
Ross I am new to this 52 F1, what chassis parts catalog CD do you recommend. I want to be able to identify the parts with drawings. I have a 49 Ford convertible and the accompanying parts books.
Thanks,
Tom
Thanks,
Tom
You can get the 48-56 Parts CD, which includes Illustrations and Listings, here:
1948-56 Ford Truck Master Parts Catalog CD - HiPo Parts Garage
If you already are familiar with the Ford numbering system, you'll have no trouble using it.
Ross
Thanks for the parts CD info.
Also got my emergency brake / shifter issue resolved. Moved clamp to location you outlined. My cable looks to be shorter than original.
Can't run it along cab and then to clamp. Still close to shifters but nolonger rubbing.
Thanks again for your help.
Tom
Tom
johare
1983 - 2012 Ranger & B-Series
06-07-2005 01:32 PM
