Sponsored by: Real Truck
Shift lever problem
Old Feb 9, 2015 | 02:47 PM
Keepitrunnin's Avatar
Keepitrunnin
Shift lever problem
'01 F250, 4X4, 5.4. Wouldn't go into park and the lever became sloppy. Thought my cable broke but released both ends and it's good. The bracket, under the dash that the cable attaches to was loose. When I tried to tighten it, one screw just spun. The piece that the bracket attaches to broke so only one screw is holding the bracket. I adjusted the cable so it shifts but no park but now I have to replace that part which looks like the end of the shift lever shaft. Anyone else do this? What's it called? Looks like the steering column gets dropped to access. Any help will be appreciated.
Old Feb 9, 2015 | 07:43 PM
sgarder's Avatar
sgarder
Yes steering column gets partially dropped. How soon are you going to do this project? There are many steps to this project, will help as much as I can.
Old Feb 9, 2015 | 08:02 PM
Keepitrunnin
Going to the dealer to gets parts tomorrow. Doing ASAP. I adjusted the cable so that I have D & R but no park. Thinking back I had this same problem with my '96 F150. If I remember correctly, wasn't that big of a project. Thanks.
Waff78
1997 - 2003 F150
Jan 18, 2011 01:21 PM
Dale in WV
1983 - 2012 Ranger & B-Series
Jun 28, 2006 07:16 PM
dadibones
Dec 18, 2005 07:46 PM
johare
Jun 7, 2005 01:32 PM
tbird46
Aug 11, 2003 08:39 AM
