Sponsored by: Auxito
Windshield washer help
Old Aug 16, 2005 | 05:09 PM
Medic24's Avatar
Medic24
Smile Windshield washer help
Hey all. a newbee to the boards here.....actually looking for a few things here/\
Recently purchased a 1997 F-150, no owners manual...so I was hoping to find an online manual, specificly looking to find list of fuses.
Which leads me to my next need.......the windshield washer is not working...cannot hear the pump run, so the first thing I would love to check of course is the fuses...anyone happen to know which number it happens to be on this model year?
the last thing I was looking for, is.....if it is not the fuse causing the failure....any ideas where next to look?
And oh yeah...before any one suggests the obvious...the washer tank is full.
Thanks all!
Old Aug 16, 2005 | 05:26 PM
triton_2002's Avatar
triton_2002
Thanks all!
Welcome to FTE
Go to www.motorcraft.com under tech resources for the owners manual.
Old Aug 17, 2005 | 06:36 PM
dlorenz's Avatar
dlorenz
I hate to tell you this, but it may be the MFS (multi-function switch) - I didn't realize this untill I lost my headlights - if you get a Haynes manual, it will show which connections are for which function (windshield washer, high/low beam, turn signal,...).
About $100 at Ford - Haynes also tells you the ritual for getting it off - the only special tool needed is a torx screwdriver. It's not hard to do.
Old Aug 17, 2005 | 08:38 PM
TheDuck's Avatar
TheDuck
I think I would verify for sure if I did or did not have power to the washer motor before I started replacing parts. I have seen these motors fail before and checking is easy with a voltmeter.
Old Aug 20, 2005 | 12:56 AM
hood's Avatar
hood
Medic24,
Locate your windshield washer jug and look near the bottom or side for the pump that is attached to it. Check to make sure that the electrical connection is plugged on.
You can also put a voltmeter to the electrical plug connection, put the washer on, and see if you have voltage going to the meter. Voltage to the meter would indicate that your pump is bad.
My 96 cougar sprung a small leak from the washer pump, so i removed the pump, applied some JB KWIK to the pump seams and saved myself $22 for a new pump.
Good luck, update your progress.
-hooD
apache12
Oct 15, 2020 01:51 PM
Ford4Fun
Electrical Systems/Wiring
May 31, 2012 09:41 PM
9explorer8
Sep 8, 2010 03:09 PM
k7ikuzus1k
Jun 25, 2008 01:31 PM
gunner5176
1983 - 2012 Ranger & B-Series
Oct 21, 2006 02:19 PM
