Blocking diode in factory wiring?
Old Aug 15, 2005 | 02:58 PM
smitty240's Avatar
smitty240
Question Blocking diode in factory wiring?
Does Ford install a blocking diode so that the trailer will not drain the truck's battery if connected to the trailer wiht the towing package? I have 12 volts at the connector with the switch on, but I'm not sure if the truck's wiring contains a diode to prevent draining the truck battery if left connected. TIA.
Old Aug 15, 2005 | 04:27 PM
Gene W's Avatar
Gene W
It has a relay that only allows the trailer 12V circuit to operate when the truck is running.
Gene
r___r
Electrical Systems/Wiring
Dec 2, 2014 03:52 PM
mojs
Modular V8 (4.6L, 5.4L)
Dec 4, 2012 10:03 PM
DeathSpiral
May 6, 2010 11:13 AM
teds74ford
25
Dec 10, 2006 05:46 PM
Greywolf
May 7, 2006 03:57 PM
