5.4l not cranking (I messed up)
Hi guys,
I wanted to change the fuel filter on my 2008 5.4l F250, and I thought it was a great idea to remove the "fuel pump diode" while the truck was running to drain the fuel pressure where the filter is located. "fuel pump diode" was according to my manual at location 62 in the engine compartment fuse box
The engine stopped directly when I pulled the diode (not after a few seconds as I expected), so I tried to start it with the diode not present, the enginge cranked but did not start.
I then inserted the diode again, and after that the engine does not even crank , instead the Securilock indicator keeps blinking (as far as I know the Truck is not even equipped with Securilock)...
Have tried to remove the battery, charge the battery, pull out fuses at random to see if they are burnt.... Running out of ideas, anyone got a good idea for me to try?
Hi guys,
I would check all fuses...& relays (fuses should be in 2 locations maybe 3?.) it maybe that when you pulled the one It set off overloaded another fuse...or during the time you disconnected the battery and reattached it??
presume you mean fuse for Diode ....and code reader will plug in properly just won't read anything
Not Sure if this helps or not but in my e-350 5.4 I have an ecu diode but not fuel pump. The diode is to prevent backflow frequencies from the cop's to the ECU\PCM. Not sure if it tripped something failsafe or possibly damaged the PCM. The diode will go in one way if it is similar to mine.
JustinSouthTex
1999 to 2016 Super Duty
07-04-2018 07:08 PM
colabronc1
04-23-2014 11:59 AM
Hard2Hear
1997-2006 Expedition & Navigator
10-12-2010 06:58 PM
