Bronco II Ford Bronco II
spindle bearings
Old Jan 19, 2003 | 01:47 PM
brnc's Avatar
brnc
spindle bearings
does anybody have a problem with the spindle bearing on bronco2 wearing out the front axles?
It always seems like i am replacing them.
Old Jan 28, 2003 | 04:54 PM
matthews_56's Avatar
matthews_56
spindle bearings
What modifications have you made to the truck? How's the alignment? Do you go off road a lot?
Old Feb 1, 2003 | 12:55 AM
brnc's Avatar
brnc
spindle bearings
go offroading alot,the brc2 is stock.
Old Feb 3, 2003 | 08:21 PM
matthews_56
spindle bearings
Could very possibly be a bent axle. Easy way to check is to have someone follow you and watch your tires at low speeds. Also, check the balance on your tires. If they are out of balance it will cause unbelieveable wear to moving parts. Hope this helps.
djmichael24951
Mar 29, 2013 02:44 PM
Ohiocrewcab
Jun 19, 2012 08:39 PM
rellik74
1983 - 2012 Ranger & B-Series
Jan 16, 2012 04:12 PM
yellow78ford
Mar 23, 2007 08:18 AM
bpctcb28
Offroad & 4x4
Aug 15, 2005 06:52 PM
