Dry spray question?
Old Aug 14, 2005 | 06:07 AM
romcjr's Avatar
romcjr
Dry spray question?
I am fixing to repaint my 92 f350 crew cab with gravity fed HVLP gun.There is not enough paint in the cup to shoot the whole truck.Will I have any problem with dry spray when I start painting again after refilling cup?I have never used HVLP before.I am an old school painter(conventional & airless).Any help would be appreciated.Thanks,Ron
Old Aug 14, 2005 | 06:47 AM
Greg 79 f150's Avatar
Greg 79 f150
Unless you are using a real fast reducer and your paint room space temp is in the high 80's, and 90's it should not be a problem, the paint should melt in. I know your concern though, thats why when I did mine, I shot the one whole side and then refilled my gun and went down the other side. jmo
Old Aug 14, 2005 | 06:54 PM
romcjr's Avatar
romcjr
Thanks for the info.I started sanding today,maybe I can shoot some paint next weekend.
Old Aug 15, 2005 | 10:31 PM
kenseth17's Avatar
kenseth17
The only coat you have to be real concerned with dry spray is the final coat. Take note of how much paint you use on the first coats, then for your final coat mix that much up in a container with maybe a little bit extra for safe measure and for hitting areas you see look a little dry a little more as you go along. Have it at the ready so you can just refill the cup without spending much time and getting dry edges. But you should be fine if the clear or paint isn't a real fast set clear and you have a slow enough reducer for the temps.
the_hetz
Paint & Bodywork
Oct 24, 2007 06:13 PM
Bill W
Paint & Bodywork
Apr 16, 2007 08:32 PM
darkman
Paint & Bodywork
Nov 5, 2003 12:25 PM
Gwilkrrs
Paint & Bodywork
Apr 21, 2003 02:21 PM
mgessner
Paint & Bodywork
Jun 27, 2001 02:18 PM
